46-420 Hippo dial pointer help?
I'm restoring one of these and the pegs in the cabinet that hold the bracket for the dial pointer have been broken off. Anybody know what a good remedy to this might be?
You could possibly (carefully!) drill a hole where the broken off peg is and press a metal pin in its place. Either a dowel pin or a roll pin might work. I'm working on my second 46-420 during this past week. Luckily neither of them had the pegs broken off, but the clips holding the pointer bracket to the cabinet didn't want to budge. Had to finally add a drop of penatrating oil over each of them to get them to loosen up.
If you still have the peg you could glue it back on with two part epoxy, remove the spring clip first though.
I don't have the old pegs so it's either find some replacements to glue on or drill some small holes and stick something in there that's a good replacement.
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural....morzh — 08:40 PM
Hickok AC51 tube tester
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
12' Philco
Bob Thanks for that photo. I have been looking for it, and I cannot find anythinmg on the web. I forgot it was here...morzh — 08:29 PM
Shadow Meter Bulb
I think after all has been said, I will use the same bulb that is specified for the dial pilot light which is a #55. I ...georgetownjohn — 07:31 PM
12' Philco
There was also this Philco! klondike98 — 07:25 PM
I expected a challenge and this is just part of it. But, it's also supposed to be fun, entertaining, informative and enj...TV MAN — 07:12 PM
Shadow Meter Bulb
Butting in here with a question. Since the shadow meter is connected directly to the 1st and 2nd I.F.'s wouldn't the met...RossH — 06:43 PM
Mike, Tim; you are about to enter the twilight zone. Doo doo doo doo, doo doo doo doo This is something alright. I'm go...RodB — 06:26 PM
