I'm recapping my PT-93 & need to know what to use to replace the condenser & choke assy.It seems to be a wire wound paper cap.(.2uf)so
can I just make one & if so what type of cap.& wire,how many turns of wire &
will it matter where I grnd. Thanks-Jim
That gizmo was to provide a low impedance ground connection at the IF frequency since it was found that the original paper caps had some undesirable self-resonant properties.
Modern caps don't have that same concern so you can use them without the extra coil. Do try to use the same grounding point if at all possible.
GL,
Bill
Chuck has an in-depth discussion on this cap/coil combo, and a later replacement for same, on his website.
http://www.philcorepairbench.com/tips/svctip37.htm
Thanks very much,will check it out!! Jim
At long last, it is aligned! I’ve uploaded a couple of new videos to YouTube to demonstrate. YouTube picked up on Hall a...jrblasde — 10:08 PM
Hello Phil, Welcome aboard what is the model number of that radio ? Sincerely Richardradiorich — 10:06 PM
Just speculating of course, but you could probably find another transformer from another car radio of the same era, pref...Arran — 09:00 PM
Hello I am new here and I could use some advice. I am working on my 1955 Stude/Philco car radio and have determined tha...Pdouglaski — 06:43 PM
Thank you MrFix55 and GarySP with helping with the Antenna, for now I am placing the Antenna on the back burner and work...osanders0311 — 02:24 PM
There are currently 2013 online users. [Complete List]
» 2 Member(s) | 2011 Guest(s)
