Philco 41-250 power transformer bad?
The power transformer in my 41-250 is putting out 250V on each HV leg with 115V input, but 7.05V on the filament winding (the tubes have 6.3 V filaments). If I go to 120V, the filament goes up to 7.4 V and the HV to 263. The power in our house is typically at 123V. The Philco schematic shows that the primary should be 12 ohms, but it tests 9,7, and it shows that teh HV secondary should be 150 ohms on one side of the center tap and 160 ohms on the other side, but it tests at 131 and 141.
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
were these voltages measured loaded or unloaded? without tubes your readings will be higher. as far as ohms on the trans,just gives an indication winding is not open,you're fine,fire it up!! after filter replacements of course,phil
A little bit of positivity in our feed... My new video... Test - the Philco 16B vs Philco 37-116 de Luxe / Test - the ...RadioSvit — 12:14 PM
Refinishing Ideas
Thanks. I will look into. Billpoulsbobill — 11:23 AM
My Philco 37-116 Restore
Why do the flood lights have 2 wires running to the shell of each light when the inner conductor only has one to each? ...dconant — 10:54 AM
OOPS!! if there is a "flag" running up the side of the tube that touches the shield, then yes, a shield belon...MrFixr55 — 10:03 AM
Thanks for pointing out that shield! I will try to find out where else it may belong. I simply installed it back where i...jrblasde — 10:02 AM
Very nice job. A real contrast between how easy the main chassis is to work on, vs how tightly the RF chassis is packed...MrFixr55 — 09:31 AM
After sleeping on it, I believe the issue is that I may have forgotten to install a ground connection between the RF cha...jrblasde — 09:21 AM
Refinishing Ideas
Hi Poulsbobl, I think that you could get away with it.  In the Philco Library, there is a parts listand specs for sp...MrFixr55 — 11:54 PM
The sleeving for the transformer arrived early, so I went ahead and finished reassembling. The chassis looks far better ...jrblasde — 10:15 PM
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
There are currently 728 online users. [Complete List]
» 1 Member(s) | 727 Guest(s)
