  • 1 Vote(s) - 5 Average
Philco 19B Shadow meter
Ive finally got this radio working after replacing the 1st IF transformer. Im looking at the shadow meter and Im not sure what I am seeing. This is my first attempt at one of these.
It looks to me that the vane stays centered all the time and doesnt move at all when tuning. It is very free to move when probed and it quickly returns to center when released (magnet ok).
http://www.philcoradio.com/tech/images/19v1.jpg
From what I understand, this is an early version and the circuit does not use a shunt resistor. If I understand correctly, with no shunt resistor in the circuit, the radio would not work if the shadow meter coil was open.
If that is true, Im thinking that the coil is ok.
So any ideas as to why isnt it working??
Could be the magnet. Measure the coil just to make sure it is not open. Then read Chuck's page that has the article about the shadographs, and I think there is something about how to magnetize the magnet again.
Or maybe it was someone else who described the magnet procedure. Just do the search.
Hunter your correct in that the schematic posted does not have the shunt resistor across the shadow meter. If the meter coil is open, you will lack plate voltage on two of the tubes in the front end of the radio. If the radio is working that coil must be good. Good movement is dependent on a strong signal in the front end of the radio.
Jerry
PS: Seems like someone tested meters out of circuit with perhaps a 1 1/2 volt battery to observe deflection. Perhaps someone can comment on that.
Just put a prescribed current through whatever way. A higher voltage will require a resistor. I do not remember off the top what current it is and what the coil resistance is, but those are listed and then it is simple I=U/R thing.
Philco Model 249 made in England
Gary - Thanks for responding!  I hadn't actually taken possession of it at the time of my post but since you said it was...fklown — 03:32 PM
Philco model 40-100
Marion; Replacing volume controls was something some service shops did in years gone by to make a little extra profit...Arran — 03:24 PM
Welcome to the Phorum, fklown!  That's one heck of a Philco 'yardstick' you've got there!  Could you possibly post a clo...GarySP — 03:19 PM
Philco model 40-100
Arran, Thank you so much for your assistance and the link to the fleabay listing! They say a picture is worth a thousan...mhamby — 01:43 PM
I wonder if anyone has any information or experience with this model.  My internet searches are coming up with nothing. ...fklown — 11:40 AM
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
There are currently 840 online users. [Complete List]
» 3 Member(s) | 837 Guest(s)
