question
i assume my 42-1010 may have the bad rubber wire in it but would my 46-1209 have it as well [ looks as if some has been replaced already] whats the chances of this david
No, 1946 models used wiring with improved insulation made of some sort of plastic - not rubber. It has not (yet) dried out over the decades as rubber did, but it does have a low melting temperature, so you have to be careful while soldering.
Post war Philcos (U.S ones) used vinyl covered wire, some Canadian made ones used cloth covered, both pre and post war as they used domestic suppliers of wire. That is except for parts imported from the U.S such as IF cans. So what you think is new wire in the 46-1209 may be original.
Mike; I've made a one or two spiders by using some card stock, and a razor blade, it took more then one try but they ...Arran — 05:48 PM
Philco 91 Restore Code ??
I wondered about that. Wish there was some place local to get this stuff.dconant — 04:20 PM
Philco 89 indicator light.
Bending the lamp bracket (moving the lamp, that is) can possibly change the shape of the pointer a bit, but not its loca...morzh — 04:01 PM
Because the usable power rating of it hen is (3,200/20,000)*25W= 4W. Maybe a tad more due to the mass, but not much. Yo...morzh — 03:59 PM
Thank you Dan, that was the trick. I kept trying to rebend the lamp bracket but that wasn't doing anything to help.Jim Dutridge — 02:18 PM
20K 25 watt. I thought it was a 20 watt at first.dconant — 01:37 PM
My Philco 37-116 Restore
Nah, too much and not that important.morzh — 01:33 PM
What's the full value of that resistor?morzh — 01:31 PM
Been running the radio for three hours now. The power transformer has settled out at 140 degrees. The filter choke is ab...dconant — 12:38 PM
Parts-express.com has them for around 5 bucks and up. You can probably get them on Amazon too.RodB — 11:48 AM
There are currently 4508 online users. [Complete List]
» 3 Member(s) | 4505 Guest(s)
