Philco 37-89 Speaker.
Greetings all,
I've a Philco 37-89 with a speaker so bad off, it will need replacement. It looks as though 80 percent of the paper cone is gone to that takes care of any possible repairs.
Two questions. First, are there any other models with compatible speakers that will work out for this old set? Second, does anyone have one they're willing to part with?
With regards to the second question, I will post in the wanted section once I find out which speaker or speaker models will work out.
73 de,
Gary/N9VU
It can be re-coned.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
BDM Wrote:It can be re-coned.
Most can. Which would be more economical? The set itself is not the most valuable and from what I can see looks wise this seems to be a common speaker <?>.
Anyone do reconing?
73 de,
Gary/N9VU
Hi Gary
The speaker used in the 37-89 is S-16. After some searching...I found that Model 38-89 also uses this speaker, but apparently no other Philco model used the S-16.
But there is good news. Philco did not give the DC resistance of the field coil in the 37-89 schematic...but they DID in the 38-89 schematic.
It is 1140 ohms.
This means that an S-7 speaker will work as a substitute. The S-7 was used in a number of Philco sets, including the following models: 60, 37-60, 37-61, 37-610, 37-620, 38-620.
I would offer to recone it for you, but so far, I have only been able to successfully recone K series Philco speakers. S series speakers have smaller voice coils and the one time I tried to recone one, it did not work out correctly. I *think* I know what I did wrong, but I have not had time nor inclination to try again.
Ron Ramirez Wrote:Hi Gary
It is 1140 ohms.
Ron,
I knew you'd come through with the information, and I thank you. I may have a ghost in my pile of sets that I may be able to sacrifice a speaker from. For now I have something to go on in the event I try to search for a replacement speaker for the set.
Thank you,
73 de,
Gary/N9VU
A little bit of positivity in our feed... My new video... Test - the Philco 16B vs Philco 37-116 de Luxe / Test - the ...RadioSvit — 12:14 PM
Refinishing Ideas
Thanks. I will look into. Billpoulsbobill — 11:23 AM
My Philco 37-116 Restore
Why do the flood lights have 2 wires running to the shell of each light when the inner conductor only has one to each? ...dconant — 10:54 AM
OOPS!! if there is a "flag" running up the side of the tube that touches the shield, then yes, a shield belon...MrFixr55 — 10:03 AM
Thanks for pointing out that shield! I will try to find out where else it may belong. I simply installed it back where i...jrblasde — 10:02 AM
Very nice job. A real contrast between how easy the main chassis is to work on, vs how tightly the RF chassis is packed...MrFixr55 — 09:31 AM
After sleeping on it, I believe the issue is that I may have forgotten to install a ground connection between the RF cha...jrblasde — 09:21 AM
Refinishing Ideas
Hi Poulsbobl, I think that you could get away with it.  In the Philco Library, there is a parts listand specs for sp...MrFixr55 — 11:54 PM
The sleeving for the transformer arrived early, so I went ahead and finished reassembling. The chassis looks far better ...jrblasde — 10:15 PM
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
There are currently 698 online users. [Complete List]
» 1 Member(s) | 697 Guest(s)
