Model 87 Tube Substitution?
Newbie here with a model 87 lowboy.
My 280 tube is broken. Is there substitution tubes I can use? The 280 is pretty expensive.
280 is a plain 80, later known as 5Z3. The globe shape of the older 280 is what drives the cost up so high.
Thanks Exray! I still have a lot to learn, but I'm working on it.
I had written an E-mail to Radio Daze about substituting the 5Z3 for my 280 and here is the reply:
We wouldnt suggested the substitution because it draws more amps from the amp - roughly 50% more. They will physically fit though.
Will there be a problem with the draw of more amps?
Possibly - the old original power transformer, now running hotter to begin with at 120 volts on primary instead of rated 110VAC, will possibly overheat with even more stress on the rectifier secondary.
Just use a type 80, which is what the transformer is rated at.
Chuck
Philco model 40-100
Marion; By "newer style" carbon resistors do you mean the molded type with coloured bands rather then the BE...Arran — 01:00 AM
hello jrblasde , your radio sounds great well done !! I bought like 20 years ago a Philco 610b that someone had painte...radiorich — 11:50 PM
Philco model 40-100
Arran, I just can't tell if the volume control has been replaced. The control has a brass shaft with one half flat for ...mhamby — 11:08 PM
Philco model 40-100
You may be able to make the part out of wood. The particular vendor has a habit of disassembling radios and selling the...MrFixr55 — 10:09 PM
Used to get to Bentonville when I worked for a Walmart vendor....nice and sleepy back then. PaulPaul Philco322 — 09:49 PM
Philco Model 249 made in England
Did Garrard produce stand-alone turntables? The reason I ask is, when I was a kid my grandfather gave me a KLH Model 20 ...jrblasde — 09:37 PM
Neat looking set, definitely Euro- style. I am guessing that this is solidstate due to the vent holes (or lack thereof,...MrFixr55 — 09:32 PM
Haha, thank you sir! I’ve been eyeballing a 47-1230 console for sale over north of Bentonville, Arkansas for a while. Pr...jrblasde — 09:18 PM
@ Joseph, get off the porch and run with the dogs. You fixed one, grab another. @ Morzh, I think that we are the same ...MrFixr55 — 08:59 PM
Wow! Now that is something! I’ve never seen a Philco like that, but it’s pretty mid-century.jrblasde — 06:40 PM
