Capacitor replacement kit
Does anyone know where to get a "capacitor replacement kit" for a Philco radio model 70 (and a few others I have around)? I read in a post from Andrew Fleck where he mentioned a kit for his model. I have done some searching and only come up with generic kits. I posted in his thread, but so far havent gotten any reply.
Thanks
Tim
Mark Oppats antique radio parts.
I go to Mouser for all my needs (I mean - electronics related Icon_lol )
Yes Mouser has caps, but Oppat will put together a cap kit for you if you give him the model number.
murf
I am all for letting Mark make a buck.
Myself, it is just that an EE in me wants to be in charge of picking caps. Icon_smile
Agree, good source and friend of forum. Also http://www.justradios.com/ and many others.
I use "Just Radio's". I've always had great service from them! They have kits for pre and post war radios with a good assortment of the most used caps.
Kevin
Sure, Justradios has the caps but not the service. I emailed them 3 weeks before I got a reply. Now I am currently at 9 days since my last contact for an error they made.
I don't buy from Just Radios even though I live in Canada, the selection of parts is not as good, and whatever they do sell is the same as what Mark, WJOE, Bob's, AES, and Radio Daze sells but at higher prices. First you need to figure out which production run of a model 70 you have, just in case there were any running changes. I've never seen the point in paying a premium for a so called "kit" of replacement capacitors when you can simply go by the factory literature and figure that out yourself, plus they almost never have replacement resistors to go along with them, I think that Mike and I are in agreement there. So what happens if they screw up? Fill out the order based on the wrong model or the wrong production run? I've made a habit of adding a complete list of all carbon resistors used in an early to mid 30s set, and often later, simply because radial lead "dog bone" resistors with a body-end-dot code have a habit of drifting upward in value as much as 100% or more over what they should be, unlike a cap going bad they won't burn anything up, at least not immediately, but the radio will not perform as well.
I agree, and I could re-iterate: I simply don't want other people making decisions for me as to the choice of parts, and also I do not know the people well enought to trust their judgement on the picks, especially the electrolytic caps as I am somehow sure they will try to meet capacitance/voltage and this will be the extent of it whereas I think that at least in some radios things like ripple current should be paid attention to also. I also want to be in charge in picking manufacturers.
Resistors are easier but still.....as long as I am buying my own caps might as well throw the resistors in and lower the per-item shipping charge.
Again, some people do not feel copfortable enough dealing with electronics and having to analyze what they need and the klits will likely meet the minimum requirements, amd then some of those who are fairly proficient in electronics still want the headache to be handed down the purchasing chain, and I am not trying to dissuade them.
Myself I simply do not have the need to do this and plus like I said it leaves me feeling being in charge of the whole process so if something is screwed up it is my own fault and no one else's.
Hey all, thanks for the advice and replies. Sounds like I am better off grabbing the Riders manual and ordering the parts individually. Thats why I wrote in. I have been following the 90 rebuild (morzh), and I am sure a lot of that will also apply to the 70. I have several others setting around that also need a little attention, so it wouldnt hurt to order in enough caps to do several at the same time.
Tim
I'd like to put in a good word for WJOE. He has very reasonable pricing and shipping, as well as many of the peculiar older cap values Philco used (at least in my case). My orders have come in about 3 days, with no problems whatsoever.
Tim
yes, though 70 close to one of them single-ended output 90s, the detector in fact the same as in 2-45 90.
And otherwise they are not as dissimilar. (speaking of which....considering I have a spare semi-junk 70 chassis, why didn't it occur to me to measure the inductance of the RF filter after 2nd detector in that chassis - they should be the same or very close. As they say in Russia, "a Russian's hindsight is always 20/20").
As a matter of fact I am about to start on my 70 now that I am done with 90, so we may do things in parallel and compare notes when needed.
Mike.
This sounds good Mike. I'd tried a PM about some details on the project, but your box is full and wont let me send. I hope to start mine next week after I finish a 'house remodel' project. Thanks all for the replies.
Tim
Tim
Let' s ask Ron, I have no messages and it shows 100%.
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
Welcome to the Phorum, Phil! Lots of friendly help here to assist you along the way! Take care, - GaryGarySP — 10:55 AM
Hi Pdouglasti, Phirst off, welcome to the Philco Phorum, a Phamily Phriendly place phull of phun pholks and all things ...MrFixr55 — 07:37 AM
There are currently 818 online users. [Complete List]
» 1 Member(s) | 817 Guest(s)
