philco 84 Ecap lead placement
I am re-stuffing the can in my 84 and I am lost on where to put the leads. I replace an 8uf and a 4uf but I dont know what wires connect to them.
Do the 2 positives get twisted together and go to the rectifier?
Or do the 2 grounds get twisted?
Not sure of the schematic since I cant read them well.
Schematics here:
http://www.nostalgiaair.org/PagesByModel...013875.pdf
Any help on this is appreciated
Kirk
Kirk,
The top-side leads definitely do NOT get tied together. The 8 uF goes to the rectifier. The 4 uf goes to the top side side of cap 32.
The negative leads are electrically connected. Don't know if they need to be twisted together or not, whichever is easier. These leads go to the center tap of the power transformer and to Cap 28 and resistor 30.
Good luck.
Jon
The pos go to your speaker (thats where all leads tie together on my 84)look at the sch at the x connections at white and green/white. When there is a dot on the sch that means that the wires are connected.
DONE!
I have a working radio with complete recapping and no off value resistors!
THanks guys Icon_mrgreenIcon_mrgreen
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
My Philco 37-116 Restore
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
There are currently 1022 online users. [Complete List]
» 2 Member(s) | 1020 Guest(s)
