37-620 BC Reception Issue
I have revived this 37-620 radio which was a basket case. This is my first radio. I receive BC signals but they are tough to lock, and I receive loud squelching just before I get the signal. Once I get the signal and get beyond the loud squelching, I have to turn down the volume or else it becomes saturated.
I have a single ended antenna connected to Input 1 with 2 connected to ground, it's length is apprx. 12 feet. It is supposed to be some sort of dual antenna with the center tap of the RF transformer grounded.(Input 3)
My thought is that the alignment might be the cause of this issue.
Any thoughts?
Thanks
A leaking capacitor may cause it to loose a station after it is "locked in"
It locks in, but will saturate if volume is turned up. Also is very sensitive to adjustments. Before station is obtained squelching is heard that you would normally would not get.
I'm thinking something may be slightly out in the oscillator circuit or the tuning capacitor. Not sure what symptoms would be seen with dirty tuning capacitor, I don't believe what I'm experiencing falls into that category.
Thanks
Has it been aligned?
Are all the tube shields in place? If not, you can easily get IF feedback which would cause this problem.
Hi
Like Brenda said missing tube shields especially the first AF or the IF tubes. Also the cap in the agc curcuit or the cap in the IF tube screen grid bypass also the second filter cap or any of the other filter caps. In other words change out all caps. There are several caps that can cause your problem. Icon_biggrin My two cents
Joe
Brenda,
That's a good idea on the shields. I will try to find some for this model. Another question on this model is the antenna setup, is it better to try a loop antenna like the one Philco suggests, or just use a single ended one?
Thanks
Single ended random wires work well with these sets.
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
Welcome to the Phorum, Phil! Lots of friendly help here to assist you along the way! Take care, - GaryGarySP — 10:55 AM
Hi Pdouglasti, Phirst off, welcome to the Philco Phorum, a Phamily Phriendly place phull of phun pholks and all things ...MrFixr55 — 07:37 AM
There are currently 774 online users. [Complete List]
» 2 Member(s) | 772 Guest(s)
