20B escutcheon
I recently bought a model 20 deluxe and noticed that the escutcheon is similar but different than my model 20 plain. Has anyone actually seen a model 20 with the escutcheon used in the promotional sales pictures that looks more like a smaller 96H escutcheon?
I never have.
Philco 21 sets use the same escutcheon as the 20, only the "PHILCO" is smaller. Perhaps this is what you have? Philco may have made the change during production of the 20 Deluxe.
Yes, the "philco" is smaller and the horse shoe design at bottom center is larger and more open. I wonder if the bezel in the original picture was a concept design.
Yup, it was a concept design. Early photos of the 70 and 90 show model 21 escutcheons and knobs, but I'm almost positive that Philco never used the 21 escutcheon on production 70 and 90 sets.
Refinishing Ideas
Hi Poulsbobl, I think that you could get away with it.  In the Philco Library, there is a parts listand specs for sp...MrFixr55 — 11:54 PM
The sleeving for the transformer arrived early, so I went ahead and finished reassembling. The chassis looks far better ...jrblasde — 10:15 PM
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
