38-12 Volume control that will not stop audio
I am restoring a 38-12 and have it playing after cap replacement and rewinding the secondary Oscillator coil. The issue is that with the volume control turned all the way down, I still have audio at the speaker. The control does vary the volume but just will not silence the radio when turned all the way down. Any ideas are appreciated.
Bill
Have you sprayed it out with contact cleaner?
Have you simply measured your volume pot and made sure it is what it says and that the wiper connects to the lower pin when the volume is all the way down (should be within 50 Ohm or so).
How loud is it when turned down?
Simple test - short the wiper and the lower pin, and see if this brings the volume down the way it is expected.
Sorry, I forgot to mention that I changed out the pot with a 500K as the schematic called for. I double checked to be sure that the wiring is OK. I checked the resistance and that may be the issue. I have 1.6 when the control is in the off position and just off of off it reads 27K. That may be a bit much??? Maybe this pot is bad. I had to attach the on/off switch to the pot when it arrived, but it seems like there is only one what to put it together.
Cleaning it (might have to open unless it has that hole in the case) and Deoxit might do the trick.
When the wiper is in an extreme position it should have a low (below 100 Ohm) resistance to the respective end terminal.
Flint Hill Bill:
I have run into the same problem with some of the new pots out there. Seems a person has to hand select each one as they are not all the same. I had a 500K that all the way down but not into the off switch it still read 34k ohms and I had the same problem with the audio still on enough that it was a concern.
Gregb
Thanks Gregb, I will have to look around for a better quality pot, if they exsist.
And thanks to all who offered comments.
Regards,
Bill
Don't necessarily look for the new pot, just clean the existing one, it might be as good as you need it, just dirty. We typically do not discard dirty pots, we clean them.
The new pot should be an audio taper pot not linear. A linear pot may have too much resistance at minimum setting.
However if it is a linear taper pot, you can try adding a 50K-100K ohm resistor between the wiper and low side of the pot. This will have the effect of unlinearizing the volume control similar to an audio taper pot. The down side is you will lose a bit of volume at the max end.
Hippo 46-420 Schematic doesn't match parts list.
Here you have the part in the sch with values. I am not sure what else is needed.morzh — 02:56 PM
Restoring Philco 37-604C
Ron Here are the two of my jigs side by side. They have been with me about the same time (a couple of month differenc...morzh — 02:05 PM
Kurt P
Terry, gotcha, thanks for the clarification.  That’s probably why the speaker seems shorted.  Assuming the OT/FC/speaker...Kurt P — 10:59 AM
Radiola 18 Amplifier & PS
I have the 2.25V and 2.5V information confused, and must look more carefully at the schematic and Hammond transformer in...TN Allen — 10:24 AM
Thank you for the information, it all helps, although understanding some of it takes time. One reason for doing the PS a...TN Allen — 09:42 AM
Hi Mike, the radio is coming along nicely but wow, you must have some serious moisture in your shop judging by the amoun...462ron — 06:29 AM
Have rebuilt the can. The can had 4 caps in it, 2x16uF, 10uF and 8uF. I used a 15uF as the first cap, 22uF and 10uF ...morzh — 09:38 PM
Philco 89B code 123 newbie
The flat copper wires are from the hum bucking coil. All of the other resistances seem to be OK.Radioroslyn — 04:15 PM
Help with weston 669
I need help with my 669 meter. I recapped it becausing it was pegging the meter out. Now the neon light comes on (not su...daveone23 — 02:42 PM
I may be incorrect but you should measure around few ohms for the voice coil. In addition you may have a hum bucking coi...RodB — 02:29 PM
There are currently 4510 online users. [Complete List]
» 2 Member(s) | 4508 Guest(s)
