46-1209 6v6gt hum and if question
I seem to have a humm I traced to one of the 6v6gt tubes. I have done a full recap. Is it ok to run a ground wire from the socket ground to the chassis ? Also my radio is still not working I get no static or anything. I have a donor chassis and I was thinking of replacing the if's from that is that ok to do ?
Just do the really methodical troubleshoot. This way you will learn something.
What does it mean you traced the hum to the tube?
The ground is OK to run to chassis but why befopre it works?
If I move that tube around the humm wil quite down. It always had a slight hum even after recap.
How can you "move the tube around" ? If the tube is in a socket it is immovable.
can you try to express your thoughts a bit more clear?
If you want help, we should not be guessing what you mean.
You should methodically explain what is going on, in good detail.
So far I did not see anything I can even try to start answering.
Yes I understand I am new at this
1. Have you tested all your tubes?
2. Have you measured all your resistors and replaced those out of spec?
3. Inspected for bad wiring, shorts etc?
4. When does the hum appear, what kind of hum is it, does it depend on the volume control?
5. How do you move the tube around etc.
Speak English, spare no detail, don't speak in puzzles.
If the noise goes away when you wiggle the tube, have you tried cleaning the socket pins? Sometimes they will make better contact if you squeeze the connectors together under the socket, with the tube removed. That works for bigger pin tubes, not sure about octals.
I vote for the socket contacts too. Have you tried a different 6v6? Could be a solder connection - it is easy to miss getting something soldered good if there is a lot of wires, or if there is oxidation on the new (or old) compenent, sometimes it wont solder good. Found this on other electronics before. I really dont think swapping parts, other than tubes is the answer. You may create more problems, and make it even harder to repair. You need to make some checks. Make sure you havent created a short with a ball of solder, bridged socket contact, etc. Do you have a schematic? Do you have a signal generator? You could have an open Rf/osc or IF coil. Check those. Sometimes an old radio isnt put into the attic for just one problem - often they start having small problems, then when things get to the point it no longer works, or the owner cant stand it anymore, it gets put up (or thrown away), so it may have several problems that will need worked through, plus any problems that happen while sitting.
Tim
Ok I ran wire to ground the tube socket and no more humm
Still have no radio at all not even static I do not have a signal generator so I don't think I can do an alignment
Do the inspection.
Your 6V67 cathodes and filaments are grounded, check that.
See if you could pass the hum from tubes before bu touching the grids.
Although I am not sure what level of understanding you have in electronics, so you have to be really careful when touching stuff. Use an insulated screwdriver.
Usually you can touch something to the volume control lugs (the three that are next to each other in a row), such as a soldering iron, this is in the signal circuit, and should make a hum in the speaker if eveything beyond that point is working. If you get a loud hum, then your problem is before that point, and mostly eliminates the audio section. Do you know how to check voltages at tube sockets? Also, this set looks like it uses some loctal tubes, which are known for contact problems between the socket and tube pins. What part of the 6V6 socket did you ground?? Likewise, I dont know how much experiance you have with tube equipment, so I may ask some very basic questions. Did you power up the radio before the recap? If so, is this problem new or as before the recap?
Tim
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 2351 online users. [Complete List]
» 2 Member(s) | 2349 Guest(s)
