Threads: 113
City: The Villages
Hi guys,
I just did a recap on this Hippo. I even replaced most of the mica caps as well as a good amount of out of range resistors. The tubes have been tested and I replaced 2 of them. Performed an alignment.
Reception is great but between stations there is a VERY noticeable squeal. Any ideas where to look?
http://www.nostalgiaair.org/Resources/634/M0013634.htm
Thanks
Eric
The Villages, FL
Threads: 146
City: Elko,MN.
I have run into this before, and have been able to get rid of it by fine tuning the alignment.
murf
Is your loop antenna properly connected? If one wire is disconnected, the set will squeal, howl, buzz, and in general not play correctly.
Threads: 55
City: Evanston, IL
If your loop is connected you may also try a slight stagger-tune of the I.F.'s as suggested above.
Chuck
Threads: 113
City: The Villages
It came with no antenna. The loop is connected but it is from what I think was a 46-250. Would that make the difference? If so what can be done to correct this?
Eric
The Villages, FL
Threads: 574
If it squeals on you tell it it is not an honorable thing to do.
And make sure it is loop and not a noose
Now on teh seriuous note, I only have the sch for 48-620, but if it is also an AC/DC set, there is a capacitor or a capacitor in series with small inductance conencting the electrical common and RF common (chassis). If this cap or inductor are bad the radio will misbehave including squealing, howling, roaring, motorboating and occasionally uttering some bad words on its own at which point you should turn it off, pull the belt from your pants, give it a good threshing and then inspect for bad parts and re-align.
Threads: 113
City: The Villages
OK Morzh, here is the schematic for the 48-460
48-460
Would it be C5?
Eric
The Villages, FL
Threads: 113
City: The Villages
Something else that I just discovered: With the antenna disconnected I get a soft high pitched squeal that changes with volume but doesn't change with movement of the tuning cap.
Eric
The Villages, FL
Threads: 574
No. C19.
But C5 is also worth checking as without it the antenna will simply not work.
Threads: 113
City: The Villages
C5 is new. Any idea why there is a soft squeal with no antenna connected?
Eric
The Villages, FL
Threads: 574
Is C19 new or is it even there?
Threads: 113
City: The Villages
Yes it is there. I have 2 schematics. This one shows a .2mf and the other shows a .5mf. I used a .5 because that is what was in there. It didn't have the wire wrapped around it. I don't think that is needed anymore. Is it?
Eric
The Villages, FL
Threads: 574
Did it have a wire wrapped around it before?
0.2uF or 0.5uF does not matter, it is an RF link cap between the two commons, either will work fine.
Threads: 113
City: The Villages
No wire, so I tried one. No change.
Eric
The Villages, FL
City: Kentucky
Hippos usually have rubber wiring. Did you replace any wires, or cover them with heat shrink? If so, check the routing of the wires. Sometimes solving a squeal is as simple as moving a wire 1/4 inch. If this isn't the trouble, i think your alignment might be a little too "hot". Like Chuck said, un-align it a little and see if the squeal stops.
Rod thank you for helping to understand the paper caps and offering the bumblebee caps. I have already ordered film caps...osanders0311 — 03:55 PM |
Bob, this is the wrong sequence to look for problems and setup circuits.
Always start checking the signal path from the...Vlad95 — 12:19 PM |
Philco J1720 stereo and record player with reverb
The above link takes you to the Delaware Valley Historic Radio club. They are not too far from you and may have sugg...klondike98 — 11:49 AM |
Tucker Movie Prop car
Richard: Did you ever check with your friend? About once a year I try to verify if Mr Rhoades really worked on the r...WrenchMonkey — 09:22 AM |
>>when turning the knobs
This is very broad.
There are knobs for tuning and knobs for volume, and possibly f...morzh — 07:36 AM |
Thx Arran, I will check the antenna connections. Right now the loop is alligator clip connected to the chassis since you...klondike98 — 03:58 AM |
Bob;
I was just thinking that maybe the 1R5 tube doesn't like being operated at 1.2 volts on the filament, though you...Arran — 12:56 AM |
So I just purchased a Philco J1720 stereo and record player. That has some static when turning the knobs. Wanted to see ...PhilcoJ1720 — 12:26 AM |
I've started looking into the very weak and garbled reception in the set (I have the HS-62A version of the chassis seen ...klondike98 — 12:00 AM |
Those last photos were not very good,so I used one of my other cameras. This is more like the true colors of the radio....Dan Walker — 10:48 PM |
There are currently 870 online users. [Complete List] » 2 Member(s) | 868 Guest(s)
