My first radio project since Christmas...I have three Fisher receivers on hold for now...
I've agreed to sell my 37-690 back to the person I bought it from. I had done nothing with it while I had it.
I pulled the power supply chassis out recently to look it over, and I didn't really like what I saw.
[Image: http://www.philcoradio.com/images/phorum...e00001.jpg]
Two bakelite blocks missing...two with terminals broken...all aluminum can electrolytics disconnected and new electrolytics stuffed under the chassis, none of which are rated higher than 450 WVDC. (The original 10 uF caps were rated at 475 WVDC.)
I also noticed that one section of a two-section Candohm resistor had been replaced - and wired in series with the original Candohm terminals.
In short...it does not meet my standards, and I don't want to see it leave here until it has been done over, and done right.
I've replaced one missing bakelite block so far. I have also ordered new electrolytic capacitors from Just Radios - mainly 10 uF, 500 WVDC for the main filter caps. These will be installed in the original aluminum cans for a cleaner appearance.
Now I wait for the Just Radios order...
Threads: 573
Ron
I understand your disdain for it....but you are selling it to THE SAME PERSON YOU BOUGHT IT FROM!!!
Why bother?
City: Lexington, KY
I think because Ron considers that person a friend, and since that person doesn't work on his own radios Ron is merely returning a favor.
You or I would do the same thing Mike, because someday that radio may be sold as once belonging to Ron Ramirez, and any shoddy workmanship would be a poor reflection, no matter how unjust.
(This post was last modified: 05-30-2014, 09:31 PM by Eliot Ness.)
Threads: 573
A friend...OK then.
The whole thing was too complicated for me to grasp otherwise.
Should I understand it so the radio then was sold as working to Ron?
Or it was never played since?
It's a good thing I have no big recognizeable name
Then again, I do not sell my radios. I buy them.
So if anyone wants to sell me a 37-690, I won't hold it against them if it has yellow caps underneath.
Better yet, it should not work at all
And you won't have to do deedly-squat about it.
Eliot Ness Wrote:Because Ron considers that person a friend, and since that person doesn't work on his own radios Ron is merely returning a favor.
Exactly.
But, H**l, just because I owned the radio for a while doesn't mean anything.
I have no disdain for the set...I just decided to cut back on consoles. The 38-690 stays, and the 37-690 will leave. That's all.
And the radio did work before I started doing this. I just didn't like how that power supply chassis looked "under the hood." And knowing how my friend enjoys playing his radios as well as looking at them...I want to be sure it is all in proper order before it leaves here.
Now, it may have a yellow cap visible here and there when I'm done. While I do have standards...I'm also not a fanatic.
City: Lexington, KY
Yeah, it's not like you don't have enough tubes in the three remaining big dog sets that I know about to heat your house in the winter even w/o the 37-690
I'm not sure if this was the case with Ron, but often when a radio changes hands among friends we often say "now, if you decide to get rid of it, let me have first dibbs." There are a few sets I have sold or traded that I probably would have otherwise kept if they weren't going to a friend.
(This post was last modified: 05-31-2014, 12:30 AM by Eliot Ness.)
Threads: 573
Ron
I meant the disdain for yellow caps and such, obviously 37-690 is not a set to have disdain for
38-690.... really? Next time you want one it won't be on the market. Or do you have two?
Threads: 54
Personally, in the unlikely event that a 37-690 and a 38-690 should come into my possession, I would be more inclined to keep the 37-690 then the latter. The reason being is that I like the cabinet design more, a cabinet with doors is much less pedestrian. Also the audio amp is a little different in that it uses push pull power triodes rather then beam power tetrodes, I don't know if there is any advantage in band coverage between one set verses the other.
(This post was last modified: 05-31-2014, 02:22 AM by Arran.)
City: Lexington, KY
I think both the 37 and 38-690's have their cabinet pros and cons and a lot of it boils down to personal taste. I think Ron had the perfect situation where having one of each he was able to pick a favorite, and I applaud his ability to do so, but I doubt I'd have the same will power as Ron when both were such nice examples. It'd be like asking a mother to pick just one of her twin babies to keep
Threads: 48
City: Tioga, Texas, USA
Ron, I agree it is the right thing to do. Getting the power supply in best condition will help the radio last many more years. Both the 37 and 38 models look nice. I would not hesitate to restore one if one were available in this area. Due to space considerations though, I would be more inclined to look for a tombstone model or a slant-front table model.
Joe
I received a note from Dave at JustRadios that the caps will ship today. So once they arrive, I can resume work by rebuilding the electrolytic cans, and then proceeding from there.
Threads: 112
City: Medford OR (OR what?)
I use the NP film caps rated to 630V to restuff cans up to 15uf and sometimes up to 22uf. That way no one will have to worry about failure, or polarity, anytime soon. Yah, they cost more, but if someone unplugs the FC speaker and turns the radio on, nothing pops.
So, where do you get these, Russ? That would have been my preference, as long as they would fit in the old aluminum cans.
Threads: 112
Threads: 573
Aren't they a tad expensive?
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM |
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM |
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM |
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM |
Thank you.
I went to your online library and found 2 schematics.
I will download and compare to components!Ken D. — 06:31 PM |
It is a 16B tombstone.morzh — 06:13 PM |
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining.
The PSU...EdHolland — 06:06 PM |
Hi Everyone,
New member but have been reading this for awhile for tips!
Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM |
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM |
Hi DConant
Yes, you can replace chokes with resistors. You do stand the risk of increased hum. the solution is to inc...MrFixr55 — 04:23 PM |
There are currently 590 online users. [Complete List] » 1 Member(s) | 589 Guest(s)
