Help with radio problem
Hi all, I hope someone will be able to help me here. I have a Philco model 91L, type 127. It's a low boy console. I recapped, checked resistors, etc. about twenty years ago. Anyway, I had it on the other night and suddenly the audio just stopped. I turned it off and back on and it seemed fine for about 15 minutes. The audio just stopped again; while going over to the radio, I noticed a blue/purple glow from the back of it. There was no odor at all nor did I hear any arcing or the such. I removed the chassis today and gave it a very close visual inspection which showed nothing at all. I'm afraid to turn it back on as I may do damage to it. Does anyone know what may cause this problem? Any help would be greatly appreciated.
Hi Tim,
Just a guess but I think I would look for a gassy tube in the audio section. My guess would be in the first amplifier. They produce a blue or purple glow when this happens. I don't think it would hurt to bring it up to look for it if you had some kind of limiting device such as a variac or a dim bulb tester. Good luck Icon_biggrin
If the high voltage is drawing too much current, the rectifier tube will often glow purple.
Your problem could be almost anywhere. I would pull and reinsert each tube to see if the purple goes away. That might get you to the circuit. Old components tend to break down over the years and develop leakage at high voltage.
If you get really desperate, I'm over here near Morristown and available most of the time. Parts, tubes, and equipment are here too.
Pete AI2V
Rogers Majestic R-646
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 1026 online users. [Complete List]
» 1 Member(s) | 1025 Guest(s)
