Philco 41-255, 42-1008 Wattage Consumption
Where can I get information as to how much wattage is drawn by a Philco 41-255, and a 42-1008. This info isn't in the service bulletins I sent for and received in July. I wish to calculate how much amperage each will draw as I'm now looking for a variac and need to know how much power handling I need to look for. Unless I miscalculated incorrectly, an old "Maggie" I used to have drew 175 watts, so at 120 VAC that's just below 1.46 Amperes.
If you cannot find anything specific my best guess would be in the 100-120 watt range as a maximum for either of those radios.
-Bill
On the 42-1008, rough calculations show between 50-60 watts. That's not a very powerful set of tubes.
You might want to invest in one of those cheap "Kill A Watt" digital boxes that show line volts, current drain, wattage, and watt hours; they cost less than $25. They can be used very effectively with a variac to monitor current and voltage. Mine has been used extensively for locating household current drain as a solar electric system comes on-line.
Pete AI2V
I don't have data for a 41-255, but the 41-250, 41-280, and the 41-285 are rated 60W, according to Riders. The 41-255 has a similar 9 tube chassis as the 41-285, so it is probably rated 60 watts as well.
The 42-355, with 8 tubes, is rated 70 watts, according to the Philco service package Chuck Schwark provided me.
John Honeycutt
Ok, thanks fellas. I'm watching ebay for some American made used variacs and some are rated at only about 2 Amperes.
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 2343 online users. [Complete List]
» 2 Member(s) | 2341 Guest(s)
