Brunswick Panatrope with Radio S31
Threads: 60
City: Kokomo, Indiana
Threads: 60
City: Sedona, AZ/Placentia/CA
Groundhog, that is just a lovely radio and the style I like. The price was exceptional. Just a classic looking radio from the era. No tubes, well, unless there are a pair of 45s, should be very reasonable to restuff it. I would have preferred something similar without the turntable but it looks like that one is complete. You just done good! I would go for that over a 12 tube Zenith. I love that screen "door" on the back. Same as my Fada 46. I hope you don't encounter and pot metal problems as I did.
Jerry
(This post was last modified: 07-11-2014, 04:18 PM by jerryhawthorne.)
Threads: 545
City: Jackson, NJ
Wow, look at the prices. We here cannot buy junk for this price.
Threads: 112
City: Medford OR (OR what?)
There are a pair of 245s in mine but mine has the B-Tully radio. Must be a month or two newer than yours.
You will probably need to re-rubber and re-magnetize the pick-up.
Threads: 60
Tube lineup looks like 4- 24's, a 27, an 80, 2- 45's and a "regulator" tube. I got a deal on a pair of 45's last fall on the bay for my Philco 95 Lowboy...I'll just keep watching. Have to figure out what the regulator tube is.
(This post was last modified: 07-11-2014, 04:57 PM by Groundhog74.)
Threads: 112
Ballast. What number is it supposed to be?
Threads: 60
Looks like it's supposed to be a D-110.
Threads: 112
(This post was last modified: 07-12-2014, 12:02 AM by Phlogiston.)
Very nice Phlog (Russ).
Jerry
Threads: 60
Does anyone know if the metal parts, dial escutcheon, tone arm, medallion, needle cups, etc. are brass, brass plated or what? I'd like to clean/polish them up but not sure how they are made and what to use when restoring. Thanks for any help.
Threads: 112
I'll look, but I think that they are nickel plated and can be cleaned if you don't get too aggressive.
Threads: 51
I would clean them, but be very careful about polishing them, particularly the dial escutcheon. In spite of what many think a lot of trim parts on old radios and phonographs were not supposed to bright metal to start with, they left the factory with a matte, an antiqued, or sometimes a blued finish. If that Brunswick were mine I would give that stuff a cleaning but leave it alone, it looks very nice as it is.
Threads: 337
City: lawrenceville nj
Wow that's very nice 2 hr drive would be worth it cabinet looks to be in great shape finish original ?
Threads: 60
As far as I can tell everything is original. There are a few flaws in the finish that do not show up on camera, small pieces of veneer chipped out on an egde etc., but nothing major. Should clean up very nicely. I thought for the price I got it for, a 2 hour drive was worth it. The only things I have noticed during initial cleaning are the power cord is frayed in a couple of places (no biggie) and the dial scale is popped loose from the tiny rivets that hold it in place at both ends, the center rivets are still holding. I found a source for a reproduction of the original owner's manual, and I will order it soon. The felt on the turntable is in really good shape, but extremely dirty. A good cleaning with something (?) will probably make a huge difference in it's appearance. Hopefully I can collect all the tubes I need soon and start on getting it working.....along with the other half dozen radios that need fixed.
Correct model 84 Ac plug an cord type
From what I read Philco went to using brown rubber power cords in 1936, so cloth was used in the 1935 and earlier models...Arran — 11:25 PM |
Hi Bruce,
I have not worked on an 84, but in general, power cords for almost any radio prior to 1938 was cloth covered...MrFixr55 — 08:34 PM |
Restoring Philco 38-14
OK, well, so after staring at the sch again, I realized the problem had to be the #12/12A padder.
I put a scope on the o...morzh — 08:15 PM |
Hello Bruce,
I mostly use brown far as my cloth powercords go !
Here is the plug that I have used bakelite Acorn style...radiorich — 08:05 PM |
Looking for as correct as can find the right Ac plug an the correct colored cloth line. Ive seen many old photos but mos...Bruce — 04:13 PM |
Rod
Two Y-caps make sense if you use them from L/N to the chassis; this is only makes sense in the transformer radios...morzh — 10:11 AM |
Mike, I'm curious about a specific use of he Y cap. Lately I've seen a single cap across the power transformer primary. ...RodB — 09:01 AM |
hello morzh ,
That sounds like a plan !
Sincerely Richardradiorich — 07:45 AM |
Richard,
It helped some, but I still had the whining when engaging the rear power strip (I did not realize it was fro...morzh — 07:07 AM |
Hello morzh,
Yes , that dreaded hum in my room where i do alighment I have my cable modem and router plus desktop plus ...radiorich — 11:25 PM |
There are currently 4153 online users. [Complete List] » 1 Member(s) | 4152 Guest(s)
