Large can capacitor
There is one big rectangle can (with 4 capacitors inside) on my 16B tombstone, located in the rear middle. Does anyone know the correct original finish (color) of it? I thought it was galvanized, but there is some sort of different plating on the top of it.
It was tin plated, like the tube shields.
It looks like tin to me.
Same material they used for roofs, tinned steel sheets. Or for canned food.
Try using some Simichrome and a cloth buffing wheel on it. Should come back to almost original condition unless it was really wasted to begin with. If it doesn't, you're only out a little buffing compound and time. Take care, Gary.
There are traces of tin on it. Under it some grey plating.When I buff with a wheel it becomes too shiny and unprotected corrosion wise. So I will probably go with steel wheel chrome spray, see how it looks like. The inside though is definitely tin, like a can of sardines.
I suspect they did start fro using empty sardine, or rather SPAM, cans Icon_smile
Judging by the gauge, it is quite possible.
I assume you are going to stuff it with younger Sardines. Unless pitted from internal or external bothers, should shine up just fine as already suggested. I've used pumice and little oil to do this, but!! goodbye decals and ink stamps if any.
Whatver you do, the result should match the rest of the set's overall impression and appearance to look as "original" as intended. Anything can be done with enough time and money.
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM
There are currently 2263 online users. [Complete List]
» 1 Member(s) | 2262 Guest(s)
