Threads: 43
City: Atlantic Highlands, NJ
Literally in parts, the cabinet is coming apart at the seams. All parts are there. The veneer is very good yet and with some glue I should be able to get it solid again. The cabinet is basically stripped eventually saving me time. Chassis is original and very clean underneath. A $25 CL find.
[Image: http://i1033.photobucket.com/albums/a414...e20fe8.jpg]
[Image: http://i1033.photobucket.com/albums/a414...eec17f.jpg]
[Image: http://i1033.photobucket.com/albums/a414...bdee63.jpg]
Threads: 573
Stripped too. Had someone tried to start refinishing?
Threads: 54
Ah, a 38-116 in kit form. I didn't know that you could remove the control panel and top that way, very interesting. I have a G.E cabinet that has a curved control panel, though it does have a separate top, even though it had some screws holding it in it was very difficult to remove.
Threads: 43
The finish just peeled off over the years. I've seen others like that, the 116B's did that too.
Threads: 54
It may have been stored in somewhat less then a controlled environment, like an unheated garage, shed or basement. Not enough to make the veneer delaminate but enough to make the lacquer start to lift and flake off.
Threads: 18
Nice set. Too bad about the cracked dial (or is it just the picture?) I think someone did strip or dunk the cabinet, but it should turn out very well.
Threads: 97
City: Poughkeepsie, N.Y.
And no grill bars.......Poor Great Philco!
Threads: 43
It has the grill bars too. They are off to the side. The glue dried out on them too and they just popped off nicely. It really is like a kit project.
Threads: 18
Kit without instruction manual. Takes an expert! We'll be watching!
Threads: 10
City: Glendale, CA
That 38-116 looks like a pretty nice project. I hope you will post some more pictures as you go along. I'm glad it went to you rather than end up in some landfill.
Tom
Threads: 43
I will definitely post pictures but wont get to it until the winter as it stands now. I have too many home projects before the summer runs out!
