Zenith 7-S-363 Electrical Restoration Opinions Requested
Hello, I am considering purchase of a Zenith 7-S-363 as my first console model. I would appreciate your thoughts if this would be a "reasonable" project for someone with "intermediate" skills. I have restored several AA5's and a few late 1940's AM/FM radios. Here is the schematic:
<!-- m --><a class="postlink" href="http://www.nostalgiaair.org/PagesByModel/354/M0025354.pdf">http://www.nostalgiaair.org/PagesByMode ... 025354.pdf</a><!-- m -->
Comments welcome.
Threads: 40
City: St Clair Shores, MI, USA
Electrically yes. Easy set to recapp/restore. Nice looking set, nice sounding set. Besides, it was used as a prop in the 1968 classic "Night of the Living Dead"
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Threads: 117
Agree with Brian!! I fully restored a 7S-363 console type a few yrs ago. Plenty of room under/& top of the chassis to do all necessary repairs indeed! The one I restored was missing most of the orig Zenith station preset "push-on" type buttons. I had to make some replacements for those. Not sure if repros are avail now but perhaps so? I saved the few origs left (2 or 3 ?), if anyone can use em in the future?, lemme know. Great sounding/and receiving radios indeed once elec restored and aligned. Seems I had to change out a bad resistor on the eye-tube harness socket to brighten the eye tube if I remember correctly. Replacing the orig rubber-grommets under the tuning capacitor mounting points is also a good idea if needed. If you cant find "repros" for those, you can also use old-style rubber faucet washers avail @ Lowes,etc. as a retrofit, by carefully drilling out the holes to proper dia. and shaving down to perfect height (thickness needed), using a exacto knife. That will be a very nice Radio once restored!! Best Luck on your resto!!
Thanks for your comments. I'll see if the seller is willing to set a reasonable price - that may take a while.
Threads: 24
City: Gladwin, MI
You can get very nice repro knobs and preset/tone tabs for this radio from Larry Bordonaro at Old Time Replications. http://www.antiqueradioknobs.com/
It is best to buy a set so that the color matches.
Ed
Threads: 2
City: Marion Il.
Hi Robert,
If you need Zenith parts try here. <!-- m --><a class="postlink" href="http://www.alanjesperson.com/">http://www.alanjesperson.com/</a><!-- m -->
Alan has many repo parts that work well. It's better to call than email. Good luck on getting your radio.
Thanks for all of your comments. I did not get the Zenith 7-S-363... but did get a 6-S-52. It has had a hard life, but perhaps there is some hope. The power transformer leads had lost much of their insulation due to someone in the past being careless. Decided to start there. Today took the transformer cover off and started putting on shrink tubing and new wires. Put it back together and checked for both open and short circuits with a VOM - looks good so far.
Lots of other problems. Certain that I will be calling on you for help as things move along.
Threads: 24
City: Gladwin, MI
Hi Robert,
I have a 6S52 on the bench here being restored. Mine has had quite a hard life too, especially the cabinet. I have the chassis recapped, aligned and playing well, but the cabinet leaves something to be desired.  I may elect to delay the cabinet work for another time. The one thing I like about these radios is that beautiful multicolor dial. They tell me you can make the dial look even nicer, by repainting the colors on the back side of it with acrylic stained glass paint (stain). I would be happy to answer any questions about the chassis that you may have, if I am able.
Regards,
Ed
Threads: 30
City: Grand Rapids, MI
Terry Burns Wrote:Hi Robert,
I just browsed the above website and the many photos therein. So that's what heaven looks like! (SIGHhhh.....).
Best Regards. Mike
"Did you say 'utes'?".
Hello - Today, I'm "Pleased As Punch" and have got to share this with you. After about a month of working on my (1936) Zenith 6-S-52, powered it up for the first time this afternoon... and it worked immediately (and quite well) on both AM and Shortwave. As mentioned earlier, had to replace the external wiring harness on the power transformer. Of course all paper and electrolytic caps were pulled. Every resistor in the radio, including the Candohm, was way out of tolerance and had to go. Even the tone control was shot. The real "kicker" was an "extra" paper cap that someone put in about 50 years ago (from the looks of the part) along with some wiring changes. Finally figured out how to bring things back to schematic. The field coil in the speaker was open, so out it went. Tried it today with a "ridiculously small" 3" diameter, permanent magnet speaker, but it sounds good to me. Will be getting suitable replacement electrodynamic model. Two encouraging factors were that all six vacuum tubes were good and there is no rubber insulation. This radio must have had a lot of use over the years, none of the tubes were the Zenith brand - guess that they were all replaced at one time or another. Still plenty to do, but have reached an important milestone. Here is a photo of the chassis, along with my Variac and isolation transformer:
[Image: http://www.vacuumtubeera.net/Photos/Zenith-6-S-52.jpg]
Threads: 40
Nice job!  Always rewarding after a such a resto. Yours was more than just a few caps and maybe a resistor or two. I rarely find tubes that are actually bad. I also find a radio is the best tube tester made. If I'm unsure of a tubes condition, I'll swap it out with several if the need arises. I've found in the past that output and rectifier tubes take the biggest pounding.
-Brian
Threads: 24
City: Gladwin, MI
Hi Robert,
Congrats on your success restoring that 6S52.  BTW, don't throw out that old speaker. Have you actually tried it connected to the radio? I have had several occasions where the field coil measured open on the ohm meter, but worked when voltage was applied. It must have welded or bridged the open when the voltage was applied. If not, the field coil can be rewound with some difficulty.
Ed
Congrats Mike,
That's a spiffy looking test bench set-up.
Thanks for your comments, but this is not Mike's radio. It is mine, and I did the work, not Mike.
Robert H.
In some countries Mike is short for Robert.
No, I don't know which countries but I do know that I don't have a leg to stand on. Sorry about the mix-up.
Chad
There are currently 2590 online users. [Complete List] » 2 Member(s) | 2588 Guest(s)
