42-380 tone controls
I have just completed rebuilds on some 42-380 chassis, including all new capacitors and resistor value check, and can't get the treble and bass tone controls to provide very much effect. This is the 4th one like this i've found. Any solution(s) would be appreciated. BTW, all the rebuilds have been VERY strong performers on both BC and SW.
Looking at the schematic, the TREBLE control should always have some effect, unless pot #53 is bad/open. The cap in series with this control should be replaced. It will be leaky or shorted.
The TREBLE pot could have been damaged in the past if leaking caps #51 and 52 allowed B+ current to pass through the pot as well, burning it.
The BASS tone circuit (loudness compensation as well) will have less effect if the volume pot has been changed out and is not a tapped type.
Well I have found 315v on the rectifier when cold. Drops off to 280 after 15 minute warmup. Checked pin 3 on both 6F6 t...murf — 04:14 PM
Thanks for the replies, I will check these ideas out and report back. murfmurf — 03:18 PM
Sorry, my mistake. murfmurf — 03:07 PM
MrFixr Honestly, I haven't done that yet and do not want to screw up the threads; maybe you could do it, or we could...morzh — 12:48 PM
Two small radios from France. Restoration and review.
Greetings; I think that it's possible that the assortment of components was the result of post war parts shortages, a...Arran — 12:18 PM
Unfortunately I can't inject any audio into the volume control. It is in the primary circuit of the antenna coil, not in...Stormlord5500 — 09:32 AM
Sounds good Gary I'll do that. I have plenty of stuff like that I can scrounge up. I am still kind of new to all this so...Stormlord5500 — 08:47 AM
Philco Battery-WWII vintage
Seems to me that this a general purpose or radio filament 6V battery of very high amp-hour capacity and very high "...MrFixr55 — 08:08 AM
Hi Morzh, From my end, no. I did not know that there are 2 threads on this topic. Maybe it should be combined.MrFixr55 — 07:13 AM
Any reason for the 2nd copy of the thread?morzh — 10:22 PM
There are currently 343 online users. [Complete List]
» 1 Member(s) | 342 Guest(s)
