90 cathedral mershon questions
Did the 90 come with the copper mershons?
Mine doesn't and most photos online dont but i have the chance to buy them.
Kirk
They came with mershons or sprague type, I've seen/had them with either or.
I have seen them with "newer mershon-likes", the nickel-plated copper types.
I think the nickel plated ones are sprague.
I bought them and the side shield off a 91. Will they fit?
My 70 also has them but one is copper and one is not. 1 was replaced right?
so putting in the copper will make it original to the 70 also?
Here is my 90 and 70 chassis:
The left one is clearly a replacement. Many of them have it like this.
If you ever restuff the sprague caps in the 90, rather than cutting it into two pieces, pop out the top plug with the two holes in it, reem the hole out underneath, then you can gut it with thin needle nose pliers, drill a small hole under the nut at bottom and another to solder under the cap for your new electrolitic. Just like the thread for the mershon restuffing shows.
Samlex heavy-Duty bench supply filter question
Hello Everyone, I have one of my Heavy-duty bench powersuplies made by Samlex it's 13.8 volt dc 20-25 amp supply. What I...radiorich — 11:24 PM
Looking for place to donate unique Philco Philco J-1930 Prototype
It's a Glaser Sears changer which Philco's engineers thought was an upgrade over a VM, but in retrospect I'd prefer the ...jeibner — 10:39 PM
AC/DC Transformer-less Sets
Joseph, Thank you for the confirmation. I knew that there must be more to the Transformer-less AC/DC radios than the ...PeterN — 10:30 PM
Good evening, folks. Power station engineer here! The east coast had pockets of DC-only power well into the twentieth...jrblasde — 10:11 PM
Model 40 does not have a rectifier, so it would be a DC only model. This however does not say anything about using...morzh — 08:01 PM
I was wondering if anyone knows if these AC/DC transformer-less sets were actually used on 110v DC anywhere, and when. ...PeterN — 06:35 PM
Given the 1960s vintage, it is likely that the cartridge is ceramic, likely more stable. The changer looks like a Voice...MrFixr55 — 05:03 PM
Jackson 665 j2 schematic request
FIXED!daveone23 — 03:55 PM
Bakelite crack repair - what is best epoxy?
Thanks everyone. I appreciate you sharing your experience and looks like I'll work with the 24 hr two part clear epoxy....de371 — 10:25 PM
Without a schematic its going to be hard tracing the wire wound spool resistors.daveone23 — 05:21 PM
There are currently 4363 online users. [Complete List]
» 1 Member(s) | 4362 Guest(s)
