A little Z restoration Chronicle DONE
Threads: 310
City: Kings Park NY
Here is a little Zenith 6D 2620 I am currently working on
Problem is that no one has the decal for it. It also needs a new dial cover. I may create a mold but I may give in and just buy one at K-town.
Image(s)
AC: 4 DC: 1
(This post was last modified: 09-12-2014, 05:04 PM by
OldRestorer .)
Threads: 310
City: Kings Park NY
Gloves on, strip, gloves off. Wow that was quick!
Image(s)
AC: 4 DC: 1
Threads: 310
City: Kings Park NY
1 veneer flaw and gone
Image(s)
AC: 4 DC: 1
Threads: 310
City: Kings Park NY
Sealed the cabinet last night and grain filled today. May need more coats. these grains are deep.
I know, I know, I should be a hand model right?
Maybe for Lane Bryant
Image(s)
AC: 4 DC: 1
Threads: 147
City: Dallas, TX
If the dial cover is not cracked or warped you may try using automotive rubbing compound use a very small buffing wheel/pad or by hand works very well. the cover will retain its patina look and you will be able to see the dial well .save your money
Threads: 51
City: San Antonio, TX
What is your grain filler of choice? Also, what color are you using...it looks like it will give a nice darker contrast in the grain.
Charlie in San Antonio
Threads: 310
City: Kings Park NY
I will try that for the dial cover but it is kinda ratty for me.
I use Mohawk Grain filler and am happy with it once I dilute it.
Kirk
AC: 4 DC: 1
Threads: 310
City: Kings Park NY
Got a little work done this morning. Taped her off and added the trim color.
Then stained the cabinet. No toner on this one. She is the same color already. Will let he dry and then clear a few coats. Someone I know is making me a decal for the front so hopefully that will work.
Image(s)
AC: 4 DC: 1
You never started collecting. It was hoarding all along.
Threads: 310
City: Kings Park NY
I really didn't start hoarding. They are all in line for restoration. I will keep one of each model and trade or sell the rest and buy ones I don't have.
I got the clear on today and now to wait for the decal....
May be a while but I got that little chassis fully recapped except for one .0005 cap
I replaced one .07 with a .1, is that ok since I am out of .068
Image(s)
AC: 4 DC: 1
Threads: 310
City: Kings Park NY
Here is the mouse house before and after. i did not do a super scrub down on this one.
Image(s)
AC: 4 DC: 1
Threads: 71
City: Linn Creek, MO
Quote: I replaced one .07 with a .1, is that ok since I am out of .068
Don't know what the application is but it will probably be just fine.
M R Radios C M Tubes
Chassis looks OK to me.
0.07 UF is probably OK to be replaced oth 0.1uF, but if you want informed opinions, show the sch link and pos #.
Threads: 310
City: Kings Park NY
Ok I am having an issue.
I am finished with the Chassis but the dial lamps are both out.
I checked everything and the only issue I see is that the 14C7 is dead.
Is this the tube that handles the dial lamps?
Here is the closest schematic I could find.
http://www.nostalgiaair.org/PagesByModel...025068.pdf
AC: 4 DC: 1
Well, when you say the tube is dead, does it also mean open filament?
With this pilot lamps will not light, or any other tube's filament for that matter.
Any open filament will keep the rest of them dead and pilots not lt.
Hello,
I am in need of a schematic for this radio. Mine has the three separate circular tube shields and a shadow me...dconant — 08:06 AM
Hello Roy,
sincerely Richardradiorich — 12:45 AM
Richard,
Had grabbed it already but thank you just the same. I find myself wanting to find some way to block out the...glyphmon — 12:03 AM
Hello roy,
Sincerely Richardradiorich — 11:54 PM
Richard,
The Silvertone 2014 also is a transformerless set, so I am incorporating a 1:1 600 ohm audio isolation transfo...glyphmon — 11:37 PM
Did an alignment today which was interesting. IF alignment went great, almost all was already spot-on. Adjusting on th...glyphmon — 11:35 PM
There are currently 1978 online users. [Complete List ]» 4 Member(s) | 1974 Guest(s)
