37 116 Standard chassis tuner
Is the tuning mechanism the same as the standard version on the deluxe chassis? If not, does anyone know what radios used the same mechanism as the standard so I can swap it out?
I have two deluxe chassis and one very nice standard cabinet. I am trying to make one radio from the parts I have.
I never saw the version with Shadow without Teledial, but I cannot imagine them to be the same as 90% of the Teledial mechanism is there to serve its function, including the mute switch etc. I would think the version without the Teledial should only have the vernier (turn gear) and coupling, there is simply no need for anything else.
Sounds like you need a 37-670 junker; the dial scale is the same as a 37-116 Standard, and I *think* the mechanism is also the same.
Thanks. My other option is to cut the cabinet hole to fit the deluxe.
Ill have both cabinets side by side in a few weeks so I will see if that works. All depends on where the standard hole lines up with the deluxe hole which is larger.
SteveJB Wrote:Thanks. My other option is to cut the cabinet hole to fit the deluxe.
NOOOO!!!!!
I might have the mechanism you need...if you are not in a hurry. I have three 37-670 chassis, and I hope to use all three to make one good, working chassis. So I won't need one of the dial assemblies. But I am extremely busy on a house project at present, and I have next to zero spare time. What little spare time I have, I spend on here. Icon_smile
Thanks Ron. I am in no hurry. I wont get to it until the winter. Thank you for your offer.
Philco 60 Power Trans
Dan; I take it that you mean that the H.V winding reads 157 ohms on one side of the center tap, and 177 ohms on the o...Arran — 07:00 PM
New find. 91X code 225
Hello, I have a Philco 91 code 121 (one speaker). I found more info here that might be of some help. Might want to fo...dconant — 06:42 PM
Hello, The HV winding on the trans is about 700 volts no load. My meter (Fluke 115) only reads to 650 volts so I meas...dconant — 04:18 PM
Thanks all. To be honest I don’t know what to make of it being in this cabinet style but I like it a lot. I specifically...pdieten — 12:47 PM
Nice grab! It appears to be a 19X cabinet. This wasn't unusual. Philco often retrofitted to other cabinets as invento...GarySP — 12:32 PM
I would certainly write down step-by-step the progression of disassembly of the works, and probably cuss out the electri...GarySP — 12:18 PM
Nice looking! This annotated schematic from our library shows parts that are slightly different in the early and later ...klondike98 — 11:33 AM
LOL!! Well Arran, if you do dive into it and come across any advice on dealing with accessing components let me know. I...klondike98 — 11:56 PM
Bob and Gary; I have the further complication on the Phillips that they decided to use some 200 volt rated paper caps...Arran — 10:05 PM
Thx Arran & Gary. Yes its super crowded in the chassis and I've debated whether to try to restuff caps or not. I t...klondike98 — 07:40 PM
