A little Z restoration Chronicle DONE
Threads: 310
City: Kings Park NY
Hey Mike!
Radio works fine so no open filament i guess but when I plugged it into the tester it sparked inside and showed 0 on the meter. I actually did not test the radio after that. maybe it did blow now?
I'll get a new tube and see what happens.
I just thought that tube moght control the dial lamps
Kirk
AC: 4 DC: 1
Threads: 566
Kirk
If you read your post, (remember, English is my second language), your times are so confused I cannot make heads or tails of whether your radio works despite blown tube, or it does not....
Try to stick to the chronological order....
Threads: 337
City: lawrenceville nj
Threads: 310
City: Kings Park NY
well, she is dead now so I guess that 14C7 is blown. Funny, it did not blow until I tried to test it.
hopefully when I get the new tube it will fix the problem.
Thanks for the help
Kirk
AC: 4 DC: 1
Threads: 566
Bad switches / bad setting on the tester?
Or, switching while the tube is in and the voltages are applied?
Threads: 310
City: Kings Park NY
Well, A buddy made me a decal and it is perfect except for the color. He does not have the gold in the middle but it is the perfect size.
Better than $16.00 for 4 at radiodaze.
I think I can live with it but i'm not sure....
what do you guys think?
Image(s)
AC: 4 DC: 1
Threads: 566
This is the wrong forum to ask this.
You know how people here are: the uglier a Z is, the better
So whatever the answer is, you have to take it with a grain of salt.
Threads: 55
City: Lexington, KY
He did a nice job but the lack of gold would bother me. I guess white and gold are two colors we can't duplicate very easily with homemade decals.
Threads: 566
OK, Kirk, don't let John in. Or when he comes, turn the Z away.
City: Sedona, AZ/Placentia/CA
I agree with John, even though it is a Z it does deserve proper coloring on the decal. Excellent job on the graphics but inkjet printers other than black are too transparent when used on decals. They pick up the wood color and of course as John indicated, no gold or white.
Kirk, spend the $16 for a set of 4 and sell the extras off for $8 apiece to others in need! You could make a little money.
Best, Jerry
Threads: 310
City: Kings Park NY
I knew that would be your answer guys
I guess it's back to radio daze...
Now I have to try and remove it
AC: 4 DC: 1
Threads: 566
Next time post them before pasting. This will save you the trouble of removing.
Mike, your cruel!
Ya never know what they will look like (home made decals) until applied when you see the true colors. I have tried many times. I love to read the bantering back and forth between you and Kirk. Don't pick on Kirk (I know your friends) I enjoy reading the stuff but your spelling is absolutely terrible. Kirk is better. My spelling is only slightly better but credit to both of you. My Spanish is bad and my French is even worth.
Enjoy your dialog back and forth.
Best, Jerry
Threads: 566
My spelling is great! But the touch keyboard on my iPad creates lots of typos. You think you pressed a key and what you pressed is the one next to it.
Threads: 310
City: Kings Park NY
Case in point: your French is even worth
Friends? I don't even like him
I give him hot chassis hoping he will get shocked real good
I even solder the b+ to the ground sometimes
Kirk
AC: 4 DC: 1
(This post was last modified: 09-05-2014, 05:16 PM by
OldRestorer .)
Mike;
I've only run into a speaker with an open filed coil twice, and they were on newer speakers from the 1940s. One ...Arran — 12:48 AM
Yes, this is my plan for now and what do I got to lose, this is not even the speaker from this radio, but one o...morzh — 10:44 PM
Mike;
I would unwrap the field coil, and see if maybe there a break near one of the ends, like where the coil wire att...Arran — 10:23 PM
...and this is what I did. I fed a little LT into the screwholes with a small brush, and a little on the rim next to the...morzh — 09:52 PM
Philco 40-120C Restoration
I combined the two 40-120C threads together as we like to keep the discussion of the same radio together. It helps with...klondike98 — 09:36 PM
Philco 40-120C Weak, Distorted Ouput
Just checked were I buy tubes price is four dollars. So living in Florid we have a local source for tubes. David David — 09:14 PM
The higher voltage may be due to higher mains voltage. My mains run 120-125AC when the set was new mains would be 110-11...David — 09:09 PM
Thank you for your reply. I pulled a speaker from a Philco 41-221 and received the same result. I used a signal tracer t...bluecap — 08:45 PM
Have you tried a different speaker?
How did you trace the distortion?
How do you know it is weak? What is the reference?...morzh — 08:33 PM
Amen to that! Every time I think I’ve captured them all, I realize that there’s another error. My goal is to finish with...jrblasde — 07:00 PM
