1929 Philco Model 86 Restore on Youtube
Threads: 42
City: Jeffersonville
State, Province, Country: PA
Howdy Buzz -
I'm restoring a 29' model 87 Lowboy and about to tackle the condenser bank myself. Would radial caps be a better fit than axial for this circuit?
Threads: 545
City: Jackson, NJ
Having done the same, the axias are better - easier to mount and create busses when needed.
Threads: 42
Threads: 59
City: Portland, Oregon
Part 7 now uploaded
https://www.youtube.com/watch?v=P7wK4-YDRCY
Threads: 337
City: lawrenceville nj
buzz
great vids funny as H**l keep them coming
Threads: 59
Part 8 now uploaded if interested
Buzz
https://www.youtube.com/watch?v=LgcaleMKk8g
Threads: 268
Hey Paul
I repaired a model 87 a year or so ago. Did chronicle the work here on the Phorum. You can do a search to find it. One of my favorites of the early sets.Definitely use mylars in the power supply, I didn't and the input cap is shorted after abt 6 months of use (3hrs a day or so).
Terry N3GTE
(This post was last modified: 09-14-2014, 07:39 AM by Radioroslyn.)
Threads: 42
Hi Terry -
Thanks for the tip! I placed the cap order last week but did not order Mylars. I'll put in another order. Really appreciate the advice.
Regards,
Threads: 545
City: Jackson, NJ
111 is not unlike those, I also used films in the power filter. After all why use electrolytics where they were not before and the capacitance needed is 2uF tops.
(This post was last modified: 09-15-2014, 12:31 PM by morzh.)
City: Sedona, AZ/Placentia/CA
I[m a great believer on the solen fast caps for low mfd power supply caps in radios. Tried e-caps in a Scott and blew out after 7 hours of running. Tried a new set with the cap cover off (stuffed) and an hour they were getting very warm. The Solen cap in there, cool. Same experience as Terry, different radio.
Best, Jerry
PS: Mike, I used them in my 111 and 112 as well!
(This post was last modified: 09-15-2014, 03:05 PM by jerryhawthorne.)
Threads: 545
City: Jackson, NJ
Jerry,
I remember, you posted the photos in my thread.
As for the ecaps, when used in large pserul radios, one needs really to pay attention to the ripple ratings. I is not a cap's fault it is used under conditios outside the specifications.
And, unfortunately, ecaps of small capcitance also have small rippe current rating, a 20uF cap going possibly to 200-300 mA, which means that one needs to patallel-serialize them to meet the requirements. Good rule of thumb is, need an amp, rate an amp (very conservative folks go 5-fold). For continuous operation in enclosed space I would also rate at least 2-3 times the load.
But those caps sold by hobbyists websites are GP caps, not even high-ripple which you need several.
Yes a film cap is better, though I could never find their ripple specs.
(This post was last modified: 09-15-2014, 03:28 PM by morzh.)
Mike, you are correct, there are other things than voltage rating and mfd values that come into play. I like many people who are not a tune to things like ripple and current, learned the hard way. Easy to say a 2mfd cap at 500V on the schematic and find an e-cap will not last, with some neat disaster happening. Thank heaven the scott had a fuse. I'm certain poly caps will work fine, I like the solen fast caps as higher quality than the polys.
Best, Jerry
Threads: 59
Part 9 now uploaded if interested
Buzz
https://www.youtube.com/watch?v=KMCM-McSfgE
(This post was last modified: 09-22-2014, 07:54 PM by Buzz.)
Threads: 59
Part 10 now uploaded if interested
Buzz
https://www.youtube.com/watch?v=aUkoNQYdh7o
Threads: 59
1929 Philco Model 86 Restore Part 11
now uploaded, if anybody is interested.
https://www.youtube.com/watch?v=Cn5ekGqZ8Bc
Correct model 84 Ac plug an cord type
I remember a bakelite "lampshade" (a fancy lampshade) style plug being available in the hardware store when I ...MrFixr55 — 10:39 AM |
Hello Arran
Yes, I also like the lampshade style plug !
Sincerely Richardradiorich — 08:46 AM |
Restoring Philco 38-14
Hello morzh,
Nice explanation on the x and y capacitors and glad you are narrowing down the issue with this set !
Si...radiorich — 08:43 AM |
From what I read Philco went to using brown rubber power cords in 1936, so cloth was used in the 1935 and earlier models...Arran — 11:25 PM |
Hi Bruce,
I have not worked on an 84, but in general, power cords for almost any radio prior to 1938 was cloth covered...MrFixr55 — 08:34 PM |
OK, well, so after staring at the sch again, I realized the problem had to be the #12/12A padder.
I put a scope on the o...morzh — 08:15 PM |
Hello Bruce,
I mostly use brown far as my cloth powercords go !
Here is the plug that I have used bakelite Acorn style...radiorich — 08:05 PM |
Looking for as correct as can find the right Ac plug an the correct colored cloth line. Ive seen many old photos but mos...Bruce — 04:13 PM |
Rod
Two Y-caps make sense if you use them from L/N to the chassis; this is only makes sense in the transformer radios w...morzh — 10:11 AM |
Mike, I'm curious about a specific use of he Y cap. Lately I've seen a single cap across the power transformer primary. ...RodB — 09:01 AM |
There are currently 3306 online users. [Complete List] » 1 Member(s) | 3305 Guest(s)
