40-190 Antenna
How can I best simulate the 40-190 antenna while I troubleshoot the radio?
http://www.nostalgiaair.org/Resources/339/M0013339.htm
Thank you,
I have an adjustable loop antenna that I use for things like that. Mine is a Terk, and there is alway the Select-A-Tenna. Both are available for sale online.
No other loop will substitute for the original, unless it is another loop from a 1940 Philco 40-180, 185 or 190. The loop is part of the set's front end and the radio will not function properly without it.
Wow Squire, it really works well. I just happen to have a Terk which usually sits behind my Pioneer receiver which has an AM rod antenna. It does not need to be connected to the Pioneer but I hooked it to terminals 1 and 4 on the Philco and I receive many loud stations now.
Great idea since I repair many Philcos from all over the country and do not want to have them ship the radio, speaker AND antenna.
Thank you,
You will never be able to obtain optimal results with anything other than an original 1940 loop. In addition, you will not be able to properly align the set with the Terk loop.
Have an extra loop from a 40-180 if your interested.
Let it go for $20 plus shipping.
Let me know if interested.
murf
Tim, nice write up and thanks for sharing !! Sincerely Richardradiorich — 02:47 AM
Well, this was a real "Hum-Dinger" :lol: ! This will be kinda long, but hopefully it will help others having t...TV MAN — 01:55 AM
Shadow Meter Bulb
Philco 41-608 changer coupler
12' Philco
12' Philco
Hickok AC51 tube tester
Arran If the wire inside cans is the gauges you mentioned, the sole reason for that would be mechanical, to stiffen t...morzh — 12:56 PM
12' Philco
Rod, Yes, I know, but the Giant Philco is not around anymore either, so I go by whoever was alive fairly recently. H...morzh — 12:54 PM
