Filters in 37-600-- WHERE?
I'm working on a 37-600, wanted to start with the 4uF and 8uF filter caps. This is my first set with the Bakelite cap blocks and I'm having a problem navigating under the chasiss. There are 3 blocks, all of which house low-value bypass/coupling caps (3615-DG, 4989-DG, and 3793-DG).
The filter caps are identified as part 31-2149 (which I can not find on the electrolytic cap listing at http://www.philcorepairbench.com/lytic.htm ). On the schematic, the filters are identified as part 35, but I can not find any such part number in the call-out of under-chassis parts (schematic at http://www.nostalgiaair.org/PagesByModel...013206.pdf ).
I can not find anything which looks like discrete filter caps, and there are no other blocks.
What am I missing??
Thanks for any guidence/help!!
Try the rectangular can mounted between the IF transformer and the power transformer.
It isn't identified, but since I do not see any drawing of a conventional cylindrical electrolytic, I'd bet that is the part you seek.
I've never owned, or worked on, a 600 or 37-600; only 602s and 37-602s, which do have a conventional multi-section electrolytic.
DOH!
I feel like a real dummy missing that. I focused on the under-chassis area and those Bakelite blocks, and kept looking for the mysterious "Part 35." I haven't pulled the cover off the filter caps yet, but may be back for more info once I do that!
Thanks so much for the quick response!
Don't feel bad. Anyone could have missed that, seeing as how the electrolytics are not identified in the parts layout drawing.
Thanks for the confidence-building comments!
I have the new e-caps wired in, and with a little adjustment to the regeneration control, she's playing quite nicely sitting on my basement workbench. I still have the other caps to attend to, and will check the tubes to see if they're up to snuff. The alignment looks like it will be a major PITA -- calling for a feeler gauge to set the tuning cap initial position!
I'll probably be back for more hand-holding!
Philco model 40-100
Thanks Arran and MrFixer55 for your input regarding my post. I think I will just fix the on/off flag in place so that it...mhamby — 07:19 PM
Thank you for the reply Arran. I will do as you suggest and report back.Stormlord5500 — 03:34 PM
Arran, Thanks for digging into your radio library. The Studebaker radio model is AC-2687/S5524. It has a power/ speaker...Pdouglaski — 02:04 PM
Philco Battery-WWII vintage
Yep. It had handles on either side, and it took two reasonably strong men to carry it. We had that Soviet FIAT 500 c...morzh — 11:45 AM
PT-6 finished!!
I’ll get on doing that and see what happens. Just to keep this all in one thread - Anyone know what length/size is u...bridkarl — 10:01 AM
Hello Ed, Well done on your part anyway that radio uses neon bulbs ? Sincerely richardradiorich — 09:43 AM
PT-6 finished!!
I agree with Ron. That’s how my 49-906 behaves. That’s why I’m curious if the bulb stays at full brightness if the recti...jrblasde — 07:54 AM
I don’t know exactly how dim your pilot gets but this is the typical of the response of many transformerless AA5s where ...462ron — 07:38 AM
Well Philco did start out in the lead acid battery manufacturing business, and I think that they were still doing so dur...Arran — 12:06 AM
It is odd that they chose the autodyne mixer/oscillator in one version of this set, with the #15 tube, but chose to use ...Arran — 11:02 PM
There are currently 1404 online users. [Complete List]
» 2 Member(s) | 1402 Guest(s)
