40-190 Antenna
How can I best simulate the 40-190 antenna while I troubleshoot the radio?
http://www.nostalgiaair.org/Resources/339/M0013339.htm
Thank you,
I have an adjustable loop antenna that I use for things like that. Mine is a Terk, and there is alway the Select-A-Tenna. Both are available for sale online.
No other loop will substitute for the original, unless it is another loop from a 1940 Philco 40-180, 185 or 190. The loop is part of the set's front end and the radio will not function properly without it.
Wow Squire, it really works well. I just happen to have a Terk which usually sits behind my Pioneer receiver which has an AM rod antenna. It does not need to be connected to the Pioneer but I hooked it to terminals 1 and 4 on the Philco and I receive many loud stations now.
Great idea since I repair many Philcos from all over the country and do not want to have them ship the radio, speaker AND antenna.
Thank you,
You will never be able to obtain optimal results with anything other than an original 1940 loop. In addition, you will not be able to properly align the set with the Terk loop.
Have an extra loop from a 40-180 if your interested.
Let it go for $20 plus shipping.
Let me know if interested.
murf
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
