Philco 89 Detector Coil
This one has an open primary. Is it possible to rewind or is there someone that does rewinding? P/N is 32-1063.
Any coil an be rewound.
Those 1-layer on a large diameter bobbin are not bad at all.
That's good news. What is the wire size?
Thank you,
Hi Dale,
There are several threads pertaining to model 89 coil rewinding under the electronic restoration tab. You can do a search or scroll through the threads under that tab. This one might be somewhat helpful: http://philcoradio.com/phorum/showthread.php?tid=8753
The best way is simply to measure it with calipers or a micrometer.
Wach your direction, count turns, and try to replicate geometry as close as possible, meaning lengtsh of windings and location of them on the bobbin / relative to each other.
This way you duplicate both the inductive coupling and inductances.
Take photos / make sketches.
If just one winding is open, and the other looks good, no green stuff etc, rewind just one.
There is something about baking old bobbins....I don't but maybe there is something good in doing it.
I was able to repair the detector coil primary and the 44 gets plate voltage now. Primary resistance is 1.4 Ohms.
When I apply a large signal to the antenna connection, it is visible at the 44 grid but all that appears at the 44 plate is a small amount of the modulating signal and no RF. Voltages are correct and 44 tube is good. Suggestions?
http://www.nostalgiaair.org/Resources/877/M0013877.htm
Thank you,
I think what you see is OK.
Are you receiving or are you able to pass moulated RF signal from your gen and hear the tone?
My input level is +10 dBm from a signal generator.
Signal is greater at the 77 grid. Oscillator dead, can anyone guess the cause? Correct, the Oscillator coil is bad. Yes, the tickler that I have read about. Took the coil out, verified the open, counted the turns with a needle (tedious) and measured the wire size to be #36. Will wind tomorrow. Thank you for the help.
Oscillator coil tickler section rewound. Radio working fine. Thanks for your patience.
Great news ! Congratulations !
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 795 online users. [Complete List]
» 1 Member(s) | 794 Guest(s)
