Cracked bakelite foot post
This cracked post is for a rubber "foot" that screws into the little metal insert you see in the photo.  This is a 53-1350 radio phonograph and is made from the bakelite material.  The little insert cannot be held by the cracked post.  Anyone have any suggestions for building up the post so it can hold on to the threaded insert?   I thought perhaps either using an epoxy type glue or perhaps some sort of fiberglass resin??  I tried wood glue, but it does not stick to the bakelite.    Thanks people.
(10-01-2014, 09:29 PM)ODPILOT Wrote:  This cracked post is for a rubber "foot" that screws into the little metal insert you see in the photo.  This is a 53-1350 radio phonograph and is made from the bakelite material.  The little insert cannot be held by the cracked post.  Anyone have any suggestions for building up the post so it can hold on to the threaded insert?   I thought perhaps either using an epoxy type glue or perhaps some sort of fiberglass resin??  I tried wood glue, but it does not stick to the bakelite.    Thanks people.
Try Plast-aid multipurpose repair plastic.  You can even make parts and knobs with this stuff
www.plast-aid.com
Wow.  I watched the past-aid video - I think that may be exactly what I need.  Thanks - I'll give it a shot.
That looks like AWESOME stuff! I need to do something to repair a part on my Synchrophase radio - the little plastic cup that holds the chains for the tuning dials has broken off. I bet this stuff could be used to make a new cup to hold the chain.
Thanks for sharing!
wow now that could  be useful  pretty cheep too
let us know how it work please
sam
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural....morzh — 08:40 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
12' Philco
Bob Thanks for that photo. I have been looking for it, and I cannot find anythinmg on the web. I forgot it was here...morzh — 08:29 PM
Shadow Meter Bulb
I think after all has been said, I will use the same bulb that is specified for the dial pilot light which is a #55. I ...georgetownjohn — 07:31 PM
12' Philco
There was also this Philco! klondike98 — 07:25 PM
I expected a challenge and this is just part of it. But, it's also supposed to be fun, entertaining, informative and enj...TV MAN — 07:12 PM
Shadow Meter Bulb
Butting in here with a question. Since the shadow meter is connected directly to the 1st and 2nd I.F.'s wouldn't the met...RossH — 06:43 PM
Mike, Tim; you are about to enter the twilight zone. Doo doo doo doo, doo doo doo doo This is something alright. I'm go...RodB — 06:26 PM
:lol: We need to start a singing radio group! I play the guitar, so maybe get a few vocals? Anyways, Mike, I did try mou...TV MAN — 05:56 PM
There are currently 6480 online users. [Complete List]
» 3 Member(s) | 6477 Guest(s)
