Model 610 bakelite block
I gutted the bakelite block for condenser C23, and now I'm not sure how the replacement capacitors are supposed to be connected.  This is Part No. 4989-FU, with 0.09 and 0.01 mfd capacitors.  This block does not have an electrical ground connection to the fastener.  Can someone help?
If you go to The Philco Repair Bench site you should be able to find all the info that you need.
                                  Henry
Ron also has some info posted on Philco Radio including a the Service Bulletin No. 289 datasheet.  Note that 4989-FG is listed but not the FU version.  The U means the #1 lug in NOT grounded and otherwise the capacitor values should be as listed in the chart and connected as noted in the diagram.  Check the schematic to make sure this makes sense as they are occasionally wired differently.
You may want to check the service bulletins for your set. Schematic sez the .1 does go to gnd.
Thanks for the link. The way my radio is hooked up, the .01 capacitor would have been wired between lugs 2 and 3, not 1 and 2. Plus I get a ground at lug 3, not 1. So it appears the wiring was done correctly per shematic, just backward at the bakelite block.
Good Job. If no one has said Welcome I did! Best of luck w/your 610 it a good performer for a smaller set. I'm sure you'll enjoy it when you get it all together. Is it a table or console model?
Thanks, Terry. This is a table model. Waiting in the queue are three consoles --- 37-620, 90, 91, and a tabletop 20. I'm hooked. 35 years ago I restored a fully working 42-1013, that now needs a full electronic restoration.
I've got the 37-620 in a chairside set. The cabinet is pretty beat and haven't gotten around to get it running again. 90 and 91are great sets the only bad thing is they only cover the BC band no SW for the most part. The later 91's have the old police band. The 20 is an excellent sounding set of you hookup a good pm speaker to it. I found that out when I was doing some troubleshooting just disconnected the V/C and wired it to a 8 or 10" modern speaker
CT Radio Museum
Hello wjreese, How Cool is that !! I read some history on them and it really sounds like they have nice place and lots...radiorich — 12:27 AM
CT Radio Museum
A great looking museum! Thanks for posting your visit.klondike98 — 11:08 PM
National NC-57 case
I have some of that so I’ll try it. That works great on my Philcos. This radio was a gift from a friend of mine so I’m ...bridkarl — 05:54 PM
National NC-57 case
As far as the cabinet condition, try cleaning it with Goop (non-pumice) hand cleaner and 0000 steel wool. GENTLY! You'l...GarySP — 05:35 PM
National NC-57 case
Yea. I think a repaint is order.  I probably have a spare bandswitch knob somewhere. Since this is an AA-5 type desig...bridkarl — 05:27 PM
Philco model 512
The one I restored had an RCA 100 speaker, the big cast iron one that produced sound from both front and back.RodB — 09:35 AM
National NC-57 case
Not only is the paint chipped out but it has dent that will need to be pushed, or pounded out. The set must have been dr...Arran — 05:09 AM
Philco model 512
There was a 511, (or an updated 1929 model 65 version) Spanish Brown, model in my region, and even though it had obvious...Arran — 06:25 PM
One method that some have used is to get some hardwood dowel, of the appropriate diameter, and cutting a flat onto one s...Arran — 05:03 PM
National NC-57 case
I’m currently recapping this National NC/57. This has a scratch on the case. I guess I can sand this out and just do a s...bridkarl — 01:29 PM
