Philco 80 different components
In the diagram 80 Philco pin 4 of the second valve 36 is grounded.
In my Philco is connected to ground, so it also has a resistor and capacitor to the central terminal of the oscillator coil.
I've seen some pictures where also other devices have that connection.
The connection of the resistor and capacitor is correct ?. A which is due ?.
Thank you.
[Image: http://s3.postimg.org/jkheaeg5f/106_1.jpg]
subirimagenes
It appears to be parts 5 and 6 as per the diagram. Your fine.
http://www.nostalgiaair.org/PagesByModel...013843.pdf
Thank you for your attention.
You may want to measure the resistance from the unground side of the resistor to the cathode pin of the mixer tube. This will tell you if you will need to rewind the feedback section of the osc  coil.
To check ant coil unplug set turn on with the volume control all the way up (loudest). Measure resistance from the ANT post to gnd post. Both osc and ant coil should read 10 ohms of less. If higher it's time to break out the magnet wire.
The question is that the terminal 4 is connected to ground, the scheme does not go directly to ground, it first goes to the coil, then the resistor and capacitor and finally to ground.
The 36 tube that is connected to the coil is the mixer, the one with the grounded cathode is the detector tube.
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 2348 online users. [Complete List]
» 2 Member(s) | 2346 Guest(s)
