Threads: 79
City: Winter Haven, FL
I just started rebuilding a Silvertone 101.614 chassis. The triple capacitor metal can is missing, and I know I can just replace it with three individual caps, but the three dial lamps are missing also. Does anyone know what type bulbs these are? The schematic is really hard to read. It looks like it says type 66, but I cannot find any reference to a type 66 bulb. It will be a while before I can actually power it up, so I just wanted to replace the lamps first.
Thanks in advance.
Pat
City: Sedona, AZ/Placentia/CA
Pat, it really helps to post a picture of the radio or at least a link to the schematic so we can help.
Jerry
Threads: 6
City: Moundsville
State, Province, Country: WV
Pat,
After looking at a magnified schematic, I believe the dial lamp is a #44.
Carl
Northern Panhandle, WV
Threads: 79
(10-17-2014, 06:54 PM)jerryhawthorne Wrote: Pat, it really helps to post a picture of the radio or at least a link to the schematic so we can help.
Jerry
Sorry Jerry,
Here's the only schematic I could find.
Threads: 79
(10-17-2014, 07:24 PM)Carl Travis Wrote: Pat,
Thanks Carl,
I'll go with that. But now, I've run into another problem, thanks to an unreadable schematic.
The schematic shows two line-to-ground caps, C45 and C46. However, the chassis has one across-the-line cap, .01 @ 600V. Can I replace that with an X2 safety cap, AND and two .01 Y2 caps as well? Or should I just remove the across-the-line cap and add two line-to-ground caps, as the schematic indicates?
Pat
Threads: 270
If indeed it is a 44 bulb you may want to use a 47. It runs a bit cooler. Some sets have the bulb very close to plastics dial which can be problematic. You may have seen sets with brown or black marks on the dial. Those can be burn marks from the bulb.
The voltage for the bulb is usually connected in parallel off of the heater winding on the power transformer. Where you could run in to problem is if your set powered the bulb off of the AC line though a balist tube or the heaters strung in series. Your set doesn't. In this type of circuit the voltage and current are very important. Wrong bulb can burned out( usually very quickly), damage the balist tube or other tube in that heater circuit
Threads: 79
(10-17-2014, 07:57 PM)Radioroslyn Wrote: If indeed it is a 44 bulb you may want to use a 47. It runs a bit cooler. Some sets have the bulb very close to plastics dial which can be problematic. You may have seen sets with brown or black marks on the dial. Those can be burn marks from the bulb.
Terry Even though the schematic doesn't show it, I've got three lamps in series off of the heater windings. Still use #47?
Pat
Pat, I would follow the schematic and replace the line input with two .01mfd either "Y" or "XY" caps as indicated. Replace the existing one across the A/C line. These should be "safety caps" used in this position. They will not fail shorted which is nice across the A/C line. Many people just remove them totally. It won't hurt the radio but may increase the noise from A/C line problems.
Best, Jerry
Threads: 79
(10-17-2014, 08:22 PM)jerryhawthorne Wrote: Pat, I would follow the schematic and replace the line input with two .01mfd either "Y" or "XY" caps as indicated. Replace the existing one across the A/C line. These should be "safety caps" used in this position. They will not fail shorted which is nice across the A/C line. Many people just remove them totally. It won't hurt the radio but may increase the noise from A/C line problems.
Best, Jerry
Thanks Jerry,
Just the answer I was looking for.
Pat
Threads: 270
Hey Pat
Are you sure the bulbs are in series?? That would mean that each bulb would have to be rated @ 2v each.
Threads: 79
(10-18-2014, 08:33 AM)Radioroslyn Wrote: Hey Pat
My error, Terry.
Maybe I need to change my medication. They are in parallel.
Pat
There are currently 1477 online users. [Complete List] » 3 Member(s) | 1474 Guest(s)
