Removing wax from chassis
Hey everyone,
I've started working on my 16b and am in the process of cleaning the chassis. does anyone have any tips on what works well for removing wax from the chassis? At one point something got hot enough to melt a fair amount of wax onto the chassis. I've removed quite a bit by scraping and using a heat gun to soften the bulk of it but there is still a film that needs to come off in the nooks and crannies. Any one have any tips? Thanks!
As I remember Laquer Thinner washed off capacitor wax off tubular paper caps well....try it.
 Try paint thinner/mineral spirits on the wax first, if that fails then move to the lacquer thinner. I use lacquer thinner to remove the hard dark brown wax residue from paper caps shells, but varsol/paint thinner/mineral spirits works on the soft yellowish kind.
WD 40 may work well too. It will remove crayon from painted walls.
                                    Henry
Xylene, is a great solvent for wax.
Keith
I just went though this. I had never reinstalled my 19B chassis in the cabinet which I refinished two years ago. The chassis was partially covered in wax from a power transformer meltdown. Amazingly, the original transformer was still good...but I digress.
I first tried denatured alcohol. It barely touched the stuff.
I did not have any lacquer thinner, so I then tried mineral spirits. That did a very good job of cleaning off the mess. Icon_thumbup
My Philco 37-116 Restore
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
When dealing with noise on power lines, time to get my Jackery 240 out. Talk about clean can hold a portable am radio ne...David — 08:52 PM
Arran - I bet you're right probably vinyl, there was no rubber smell when desoldering it, which you often get with the o...EdHolland — 08:23 PM
Ed; It was very likely vinyl covered wire given the vintage of the set, there was some rubber/gutta percha wire used ...Arran — 06:34 PM
I think the problem is traced - to noise on the AC line. It sounded so local, that it seemed certain it was generated wi...EdHolland — 05:51 PM
A little bit of positivity in our feed... My new video... Test - the Philco 16B vs Philco 37-116 de Luxe / Test - the ...RadioSvit — 12:14 PM
Refinishing Ideas
Thanks. I will look into. Billpoulsbobill — 11:23 AM
Why do the flood lights have 2 wires running to the shell of each light when the inner conductor only has one to each? ...dconant — 10:54 AM
OOPS!! if there is a "flag" running up the side of the tube that touches the shield, then yes, a shield belon...MrFixr55 — 10:03 AM
