philco 42-1003
what is this? phono plugs into it. model 42-1003 not bol equipt.
It's the audio input transformer.
Most likely for a crystal type pickup to match into the audio section of the radio.
Probably modified by user or a radio shop. (?)
Note:
The 42-1003 originally had a Beam-of-Light pickup arm, as shown in The Gallery.
To be sure you have a 42-1003 set, it should have two bands AM and SW.
The 42-1001 and 42-1002 were AM only and originally used crystal pickup tonearms.
Chuck
The 2 towns you mentioned "Frustrated" and "Give Up" are places we have all been. Relax, take 5, thi...Paul Philco322 — 03:23 PM
Philco 89 Code 123 Osc Coil
Thanks for posting that information!klondike98 — 03:14 PM
From what I see is the blue cap was added by someone after the radio was sold presumably to replace cap 40A. I can't tel...RodB — 03:12 PM
Correction My original picture shows #40 cap, blue cap and #42 resistor connected.osanders0311 — 02:23 PM
Well guys I am stuck, frustrated and about ready to give up. For starters all I'm getting from the speaker is a humming ...osanders0311 — 02:17 PM
[split] New member...
Thanks.  I'll try that.HowardWoodard — 01:13 PM
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
There are currently 1132 online users. [Complete List]
» 4 Member(s) | 1128 Guest(s)
AvatarAvatarAvatarAvatar
