PHILCO MODEL 43 - CHASSIS TO CABINET WASHERS
I've been trying to locate replacement washers which go between the chassis and the cabinet of the 1932 vintage Model 43 Cathedral Style radio I am restoring.  The bottom of the cabinet has recessed holes for the washers, with an approximately 1" diameter with an inner recess of approximately 3/8".  (measured on the cabinet itself)  The height of the dried up squashed remaining fossilized washer appears to be around 5/16".  The bore of the screw hole looks to be around 3/16".  I've checked a few re-pro component sites, but can't find chassis washers with these dimensions.
Does anyone know where I can get washers to fit that will do the job?
Thanks!
Try your local hardware store in the plumbing section. Usually there are all sizes in the plumbing section...at least at my Ace Hdwe. there is.
Thanks, Art! I'll give it a try.
(12-05-2014, 03:25 PM)Art Hoch Wrote:  Try your local hardware store in the plumbing section.  Usually there are all sizes in the plumbing section...at least at my Ace Hdwe. there is.
I have recapped this large Marconi model 86.  It plays quit good.         I have stripped the cabinet and using Mohawk...Dan Walker — 12:18 AM
Table radio 51C or 52C?
I think what you may have is another Phactory Phranken Philco, if the holes in the front panel lined up it was not unusu...Arran — 10:41 PM
Ho OSanders, Sorry, I got really busy in May and haven't seen your thread in a while.  I am VERY sorry about that.  ...MrFixr55 — 10:30 PM
Philco 45L Initial Check Up
Dan; I don't think that the model 45 is especially know for coil problems, not that they can't occur for one reason o...Arran — 10:19 PM
Yes, the end with the groove is positive, the stripe with the arrows points to the negative lead. The arrows have minus ...RodB — 09:36 PM
Thank you Rod and Paul I took a break, did some yard work and Rod "Therefore, it appears cap 40 is connected backw...osanders0311 — 06:35 PM
Hello, I am in the process of checking out a Philco 45L. My question is does this model suffer from the Philco coil r...dconant — 06:11 PM
Purchased a table radio at auction, not because I had to have it, but because no one else bid on it.  $5  Unable to fi...antiqueradionut — 05:14 PM
The 2 towns you mentioned "Frustrated" and "Give Up" are places we have all been. Relax, take 5, thi...Paul Philco322 — 03:23 PM
Philco 89 Code 123 Osc Coil
Thanks for posting that information!klondike98 — 03:14 PM
