Zenith 6-S-321 - What Type of Wood is This?
This is the front of my Zenith 6-S-321.  I know the front is a photofinish but was wondering what type of wood was being replicated.  The walnut burl is obvious but what is the other type of wood that is being replicated?  The pattern with the vertical lines?
[Image: http://antiqueradios.com/gallery/main.ph...alNumber=2]
Geoff
(12-15-2014, 02:51 AM)Geoff Wrote:  This is the front of my Zenith 6-S-321.  I know the front is a photofinish but was wondering what type of wood was being replicated.  The walnut burl is obvious but what is the other type of wood that is being replicated?  The pattern with the vertical lines?
Geoff
I think that the burl that is being mimicked also could have been an olive burl, the striped stuff could be a copy of Sapele or ribbon mahogany veneer, or quarter sawn French walnut. But with a faux finish some creative license may have been taken on colour and pattern. If it were my set I would try touching it up since it does not look to be in bad shape.
It's a little beyond the "touching up" approach  Icon_biggrin.
I would have guessed the swirled front panel is camphor burl, not walnut burl.
 That cabinet is almost beyond salvaging really, is it worth doing because to my way of thinking sets that had a 100% faux finish were typically low end cheapies? I guess adding the name "Stars and Stripes" along with that magic Brand Z name is good enough for some people, but I really do hate faux finishes when they are overused that way. I'm not sure what camphor burl looks like but olive burl or even a maple burl could look similar to that with a tinted laquer on top. Here is one that someone stripped, pitty to whomever bought the thing that way, especially if they paid that asking price, even if it did not originally have that faux finish on it the one someone put on it still looks like crap:
http://radioattic.com/item.htm?radio=0120127
come on that's not beyond repair for some one here Icon_e_wink
It looks a lot worse than what it really is and the repairs should be pretty basic. The broken piece along the right corner is just the outer cheap nondescript veneer that wraps around the more solid wood underneath. The wood underneath is undamaged. I have all the missing pieces not shown in the photos. The top is an easy repair and the bottom base "foot" just needs to be glued back on. Then the entire piece of nondescript veneer across the front and sides needs to be removed and replaced with a new one. After that I need to come up with a way of creating a new photofinish. Right now I'm working with this guy on a replacement:
http://www.vintageradiolabels.com/refaux-pro.html
http://www.vintageradiolabels.com/re-fau...llery.html
If it doesn't work out I'll use actual veneer.
As for this particular model I've seen them go for pretty decent prices on eBay when they are in decent shape. Here is an example I found on the internet:
[Image: http://antiqueradios.com/gallery/main.ph...alNumber=1]
just me , but I think brass to shiny  would like more patina look to it  but that's me
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
There are currently 731 online users. [Complete List]
» 1 Member(s) | 730 Guest(s)
