Threads: 1
City: south Mississippi
I have almost completed the restoration of a Philco 38-5 big beast and am having a volume problem. The volume seems to bounce up and down and I can't figure the cause. I have already installed new caps and tested resistors and also have substituted all the tubes with no help. The radio plays great with tremendous volume and has been aligned already. The VC has been substituted as well.
Any ideas? It does this randomly.
City: Sedona, AZ/Placentia/CA
Perhaps a good time to clean tube pins and sockets well?
Jerry
Threads: 51
Sometimes testing resistors is not often good enough, I would replace the plate resistor on the first audio tube. The next thing to look into are the grid cap leads, on the first audio tube and sometimes the first detector tube or RF amplifier tubes, it may also be a grid cap itself, failing solder joint. Dirty tube sockets can also cause problems, although not usually with octals or the old six and seven pin tubes in an AC set.
Threads: 1
Thanks for the suggestions. I am new to this phorum but have been reading the threads off an on for years. This volume problem has had me stumped so I figured it was time for the experts. I will follow the ideas given in the next day or so and will follow up and let everyone how it turned out.
Again.
Threads: 1
(12-15-2014, 09:45 AM)r8i0 Wrote: Thanks for the suggestions. I am new to this phorum but have been reading the threads off an on for years. This volume problem has had me stumped so I figured it was time for the experts. I will follow the ideas given in the next day or so and will follow up and let everyone how it turned out.
Again.
Threads: 1
HI all,
Thanks for the suggestions on the bouncing volume on my 38-5. I cleaned the pins and sockets of all 8 tubes and it did not help, I then replaced the plate resistor of the output tunes and still not help. Any other suggestions? This is a beautiful radio and I really don't want to give up on it. Any thoughts would be appreciated.
r8i0
Threads: 270
City: Wilsonville
State, Province, Country: OR
How about some deoxit squirted in the volume pot #44 ? (and welcome to the Phorum!)
Threads: 1
I deoxit-ed it and the problem is still there. I am going to replace the output tubes and see if that changes things.
r8i0
Thanks for the welcome and Merry Christmas to all.
Threads: 69
City: Kansas city, MO.
Welcome to phorum. Did you by chance get around to checking the grid cap leads as mentioned by Aaron?
Threads: 1
(12-17-2014, 07:07 PM)Mike Wrote: Welcome to phorum. Did you by chance get around to checking the grid cap leads as mentioned by Aaron?
Hi Mike
I cleaned the grid caps and the connectors and still have the problem. I Just replaced the 6f6 tubes again no solution.
Almost 30 years repairing radios and this is one of the toughest.
r8i0
Threads: 69
Wish I could offer more advice but I'm a rookie 2yrs in the hobby.
Someone here will probably have some more ideas on what you might check.
Any chance you have an O'scope? Would be useful in monitoring signal at various points and seeing where the level is jumping around. Monitoring plate voltages with a meter might also provide useful information.
Tough problems and good luck.
Jerry
Threads: 1
HI Jerry,
I do not have an O'scope. I have never had the need to use one. Sorry.....
Bill
Threads: 270
City: Wilsonville
Bill, you've got a lot more experience than I do so I doubt I can help much, but I feel your pain. I've got an 84B that has a similar volume jumping around problem that I've yet to diagnose. I've prodded for loose components; looked for cold solder joints; cleaned dirty pots and tube pins but haven't located the source.
Threads: 1
(12-18-2014, 11:05 PM)klondike98 Wrote: Bill, you've got a lot more experience than I do so I doubt I can help much, but I feel your pain. I've got an 84B that has a similar volume jumping around problem that I've yet to diagnose. I've prodded for loose components; looked for cold solder joints; cleaned dirty pots and tube pins but haven't located
Good evening,
Earlier today I replaced the pair of 6f6 tubes with a pair of 6v6 tubes and the problem got worse. The bounce went crazy. Big highs and low lows. I am going to concentrate on the output for now and will report the results.
R8i0
Hi Cap'n Clock,
Unfortunately, I do not have this radio. This is a shame because this should be a good performer. 2A5...MrFixr55 — 06:48 AM |
I think it would come under either American Bosch or United American Bosch. American Bosch made sets for the American We...Arran — 05:53 AM |
Thanks to all for the feedback. As Arran said, it is probably an older replacement and yes it has a grid cap so I will ...georgetownjohn — 09:32 PM |
It's possible that the red wire, actually a grid cap lead, is a very old replacement, I can't remember seeing a pre 1939...Arran — 09:18 PM |
Gilfillan Brothers Car Radio?
Hi everyone,
Special thanks to Joe Rossi for tracking down this obscure radio and thanks to others who took up the hun...Antipodal — 08:15 PM |
Here's one source for your wire of many.
Take care and BE HEALTHY! Gary
P.S. Can't get the right color you need? I ...GarySP — 06:40 PM |
...and modern wire of the appropriate gauges and insulation V-rating (300V minimum, usually shown right on the wire) is ...morzh — 05:47 PM |
I have a question about this radio, is there anyone that has access to this radio that has an intact unmolested speaker ...captainclock1988 — 04:28 PM |
Well what makes me confuse all of those companies is that all three of those companies (Setchell-Carlson, Stromberg-Carl...captainclock1988 — 04:21 PM |
The red wire is rubber covered wire.
The others are cotton braid over rubber often in colors or a tracer, also strand...Chas — 02:43 PM |
There are currently 7061 online users. [Complete List] » 2 Member(s) | 7059 Guest(s)
