1933 vintage radio batteries for Philco 38A
I am rebuilding an old 1933 Philco 38A battery powered floor standing radio that requires the following voltages: B+135v, B+67 1/2v, A+2v, C-3v, C-7v and a common A-,B-,C+ lead. What type of battery or batteries were used on this set back in 1933? What type of connections did the battery(ies) have? ie: Fanstock clips, Carr, socket or nurled thumb nuts. Do you know where I can find a picture of the battery(ies)? My goal is to recreate a rechargeable battery pack and wrap it in the same style as was available in 1933. I have a battery eliminator for it but I want it to be as original as possible. The set is very beautiful and deserves it. Any suggestions or options you may know of would be greatly appreciated.
Thank you for your time, Tom
Here you go....
Bill
[Image: http://users.mw.net/~bmorris/details.jpg]
I have just acquired a 38A cathedral radio and would like to know where or if I can obtain the socket for the battery plug on the radio. If I can find the socket, I would connect it to a battery eliminator which has all the necessary A, B and C outputs. To the OP, you said yours is a "floor standing" 38A.. is it a console? if so, does anyone know if Philco made this model in both a console and a table-top (cathedral) form ?
Don
DonS Wrote:...does anyone know if Philco made this model in both a console and a table-top (cathedral) form ?
Yes, they did. Some examples of Model 38 consoles...
http://www.philcoradio.com/gallery/1933c.htm
http://www.philcoradio.com/gallery/1935a.htm
http://www.philcoradio.com/gallery/1936a.htm
Refinishing Ideas
Hi Poulsbobl, I think that you could get away with it.  In the Philco Library, there is a parts listand specs for sp...MrFixr55 — 11:54 PM
The sleeving for the transformer arrived early, so I went ahead and finished reassembling. The chassis looks far better ...jrblasde — 10:15 PM
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
There are currently 759 online users. [Complete List]
» 1 Member(s) | 758 Guest(s)
