Gilfillan Model 96 schematic
I recently rescued a Gilfillan model 96. Most of the tubes were gone.
My riders does not reference a model 96 so any ideas on tracking down a schematic would be welcome.
The dial scale is also in bad shape. Anyone who might be able to scan a decent one please let me know. Thanks
My Gernsback Service manual index shows a schematic for a 96B and a 96X. The B uses Metal-Glass tubes and the X uses Metal tubes:
http://www.radiomuseum.org/r/gilfillan_96.html
Send me a PM with your e-mail address and I'll send you a PDF copy.
(12-26-2014, 03:48 PM)Eliot Ness Wrote:  My Gernsback Service manual index shows a schematic for a 96B and a 96X.  The B uses Metal-Glass tubes and the X uses Metal tubes:
PM sent thank you
Schematic sent, hope it helps!
Thanks John
This is great.
Roy
Please keep us updated as you progress on this pretty rare set.
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
