Light socket repair
Any one out there that has rewired the dial light sockets on the automatic tuning sets? I have one with a couple bad wires that need replacing and thought I'd ask before taking one apart.
Looks like the socket that lights the dial/band indicator needs it as well.
I don't believe this is quite what you're asking about but Ron did a pilot lamp rewire in the tech section, maybe part if it will help...
Thank you Bob that did help Icon_smile
The rewiring went perfectly thanks to the pilot lamp rewire by Ron. The hardest thing was finding the correct plastic washers locally.
Icon_thumbup
I found a source for the #6 plastic/ nylon washers, ACE Hardware has them.They are 0.11 apiece.They are in the pullout
trays in the single nut/bolt and washer section.
(01-02-2015, 11:17 PM)doug-5er Wrote:  I found a source for the #6 plastic/ nylon washers, ACE Hardware has them.They are 0.11 apiece.They are in the pullout
That's great! I have an Ace Hardware close by. Lowe's only had 5 of them and they were much more. I was waiting for them to get a new shipment in.
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
