46-1201 Tuning Issues
Recapped my 46-1201, (Bing Crosby), and got the record player playing perfectly and with a new cartridge.  The odd thing is that when tuned to the radio side, unless I put my finger on the tuning condenser, I cannot get any broadcast channels.  When I touch it, the am channels come in loud and clear.  I tried attaching a wire to the condenser, but that only leaves garbled sounds, not clear at all unless I press on that condenser.  All the tubes tested strong also.  Does anyone have any idea what the issue is?  The phono plays loud and clear also.
One more thing, when the antenna is disconnected, the band picks up the same one or twostrange amateur or religious stations at many different spots on the band. Once I connect the 2 antenna leads, these stations go away.
Bekueve this is your set:
http://www.nostalgiaair.org/PagesByModel...013584.pdf
I'd check T1 your antenna coil and it's connections first.
Yes, that is the set. I will check the coil that is mounted on top of the tuning condenser.  The antenna leads were connected correctly, but I did not replace that one capacitor that attaches to the coil.  I am not sure if that would make any difference.
Need Help to ID this radio 11 tube Philco
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
There are currently 299 online users. [Complete List]
» 2 Member(s) | 297 Guest(s)
