Philco 511 restoration question
Hello forum-
Still working on the 511 and I have a question about the 3 -0.1uf capacitors which are wrapped with coil (one per RF circuit).  Are these tank circuits?  What modern type are to be used for replacement ? Do I just use regular caps and leave the coils intact?  Any clarification is appreciated.
Mark
I stuffed mine with yellow tube caps and 1/4w 100 ohm resistors, then I wrapped thread around the old cap to mimic the wire resistor. Then I used a black crayon to melt into the ends. Looks completely original.
Philco 38-7 Oscillation
I have let this one sit because of other duties. Now I am back, and I have a couple of questions. I hooked up a Hammond ...tludka — 11:16 PM
Philco 38-7 Speaker
I know that when I first started working on this radio, I did not even have a speaker. Once I finally found one it was n...tludka — 11:00 PM
Philco 60 Squealing
I seem to remember eliminating a squeal by changing the IF frequency by a few KHz. Not that you should put too much tru...fenbach — 08:48 PM
Philco 42-390, code 121 speaker
These speakers pop up on eBay regularly, even if at bloated prices. Honestly, have not seen many parts on swapmeets.morzh — 08:38 PM
Philco 38-7 Speaker
The put-put is not like the speaker problem.morzh — 08:29 PM
Mission Bell Model 19A Car Radio
Hello everyone,  As mentioned in my last post I was going to see if the vibrator / rectifier section could be persuaded...Antipodal — 08:21 PM
Philco 60 Squealing
Wondering if I did it backwards. If a coil was wound backwards, the oscillator would not work at all. Old school...Chas — 07:23 PM
Philco 38-7 Speaker
4-ohm speaker. Black, Green leads.tludka — 07:00 PM
#87 on the schematic.  This radio had a 8" Zenith  speaker attached to it when I got it. I do don't know the hist...Stevelog — 06:39 PM
Philco 60 Squealing
I'm pretty sure I now have the litz wire soldered. This did not make any difference. Back in April I rewound the seconda...dconant — 06:25 PM
There are currently 1267 online users. [Complete List]
» 1 Member(s) | 1266 Guest(s)
