The Fisher 700-T Receiver
Threads: 574
Headphones..or speakers...unless you tell me it was not there before....all transistor amps do that. In fact one of the way to counter that was using a relay with a delay, it would enage about 2 sec after power up when the transition is over.
The noise was not there before I reinstalled the front, top and bottom covers.
Running on headphones the entire time, no speakers connected - just the headphones. Speaker switch in the OFF position.
Oh, and the metallic "thump" sound is coming from the unit itself, not through the headphones. It only does it once, as soon as it is powered up.
Well, I hooked up a pair of speakers to it and tried it again.
Other than the metallic thump when first turned on, it sounds great. Nice and clear in both channels and the Stereo Beacon works as it should.
Later on, I'll try removing the covers and then try it again to see if the thump goes away. As I said before, the thump wasn't there with the covers off.
(Strange thing - now the on-off switch is working again.)
Threads: 574
Transformer magnetized by inrush current? Makes covers thump?
Yes - I think this is what it is. I placed my hand on the top cover, turned it on, and could feel a slight, very brief vibration in the top cover when I turned the unit on.
Is this something correctable? Or is it nothing to worry about? It's weird...none of my other working receivers do this.
And, sometimes the thump is louder than others. It is loudest when first turned on from a cold start, after sitting (off) for awhile. After it is on, I can turn it off and immediately back on and it doesn't make the thump noise.
Threads: 574
Yes that points to inrush.
When amp is cold and the caps are fully discharged the inrush current is the highest and limited by only parasitic transformer's resitance and inductance.
When turning on fast after turn off, the caps are partly charged and the inrush is smaller.
If it does not bother you, simply put some foam rubber or something soft and not flammable between the cover and what it hits aginst or something....
Okay, so it's nothing to worry about, then? That's a relief...I'll see what I can find. There is very little space between the top cover and the top of the power transformer, and I think that is where the thump is coming from.
Hey - how about some nice asbestos?
Just kidding!
Threads: 574
Hey I can send you one of the two asbesos mats from one of my to Zenith 7G605s.  Just kidding. I want to keep them for myself.
Threads: 574
There is a thing called NTC thermistor, Negative Thermal Coefficent one, some of them are large enough and are used as inrush suppressors. I used them.
http://www.mouser.com/ProductDetail/Amet...gnCA%3d%3d
http://www.ametherm.com/inrush-current/i...heets.html
You need to pick one with cold resistance so it limits the current to say 1/10 of what it is and when hot does not drop much.
Or you could put one on the MAINs side. A different model.
You mean like the CL-90 inrush current limiter?
I was just sitting here thinking that something like that might be a good thing for this receiver.
I would sure like to finish it up...it keeps mocking me, as if it is saying, "G'ahead, fix me...I dare you..."
Regarding the off-on switch: I do have one more junk Fisher to possibly draw a off-on-volume control from if I have to replace it (again). Or I could try opening this one up (again) and blast the heck out of it with DeoxIT (again).
Threads: 574
Do not use Deoxit, it protects but does not clean what is there.
But alcohol does.
Theeeen (as chinese girls say it...very melodically) you can se Deoxit, to keep the oxidation out.
Threads: 574
What is your NAINs max drawn current?
I just remember I have some from one of the pojects I did, I had to limit inrush in the piwer supply I developed for Iindia. I reduced it from measured 40A to 5A.
I might have something that would fit the application.
(02-13-2015, 11:39 PM)morzh Wrote: What is your NAINs max drawn current?
What is my what?!?
Oh, I think you meant to type mains, yes?
I'll check it later this weekend and get back to you. Getting late here  ...of course, I am on the same time zone as you but still...
Threads: 574
I have just pulled out what I have....wait a few minutes.
Threads: 574
Well, I have some for steady current of 1A and one for 1.2 A.
Ok MrFixr55,
I have tried the DeoxIT D5 on the band switch and even though it has relieved the tension I felt when turn...osanders0311 — 11:11 AM |
Is there a reference somewhere where you can punch in Philco part numbers and see what models those parts were used in?Jim Dutridge — 10:17 AM |
Hi OSanders,
Look carefully at the band switch. Turn it slowly and "wiggle" it around the desired band. ...MrFixr55 — 12:33 AM |
5U4 vs 5Z4 tubes
I think that RCA and GE introduced metal tubes in the USA in 1936. I don't know if they were being made by RCA, GE or b...MrFixr55 — 11:20 PM |
Vlad95,
Thank you for the stringing guides and wow there are so manyosanders0311 — 06:01 PM |
5U4 vs 5Z4 tubes
A pre war Hallicrafters, and an early one too, very nice! 1936 is pretty early for metal tubes too, which would explain ...Arran — 05:58 PM |
Thanks Rod,
"When you hear the background hiss and no station it usually indicates that the oscillator quit" ...osanders0311 — 05:52 PM |
RodB
:beerchug:Vlad95 — 10:22 AM |
Vlad, you nailed it. Swiss and German roots.RodB — 09:54 AM |
5U4 vs 5Z4 tubes
Well this is a Hallicrafters SX/9 circa 1936.
No real issues so far although I dodged a real bullet with a cap that was...bridkarl — 07:59 AM |
