philco 620,,,#32-1647 if transformer
Threads: 11
City: Bellmawr, NJ
I have a little problem,,,thee IF transformer has crap-out,,,Philco part # 32-1647,,,is there a cross reference number,, for this item,, in a different make that will work,,thank you for all you time,,,Ken jr.
Threads: 573
Ken
It is always nice to list the radio you are working on and give the link to the sch if it is available.
Threads: 11
City: Bellmawr, NJ
It is a Philco 620 early model,,and I Don't know how to put the link on here,, of the schematic,,,I 'm sorry for my dumbness on computers,,I don't even own a cell phone,,now that is old school as you can get it,,and barely get around on the computer ,,,thank you for your time and help,,Ken
Threads: 573
http://www.nostalgiaair.org/PagesByModel...013804.pdf
Part #37.
Judging by it being in a round can, can be re-wound.
City: Sedona, AZ/Placentia/CA
Ken, you might also post on the want to buy section of this Phorum and see if someone might have a parts chassis with a working IF transformer. Lot of people on here with parts. Welcome.
Jerry
PS: Ken, don't worry, I have a cheap cell phone and can receive and place calls. My wife has a complicated one which I guess does more but I can't even figure out how to answer. Still learning about these new computers, I wish I could go back to DOS based ones with a couple floppy disks!
(This post was last modified: 02-24-2015, 07:43 PM by jerryhawthorne.)
Threads: 573
Jerry
What you need is a smart cell phone with a floppy isk  .
And magnetic core memory.
No Mike, life is just fine! Hope your keeping warm.
Jerry
Threads: 11
City: Bellmawr, NJ
I may be wrong on the If transformer crapping out,,,the schematic says 20 ohms on both side of this transformer,now,,do the adjustment screws for alinement change the ohms "total "on these coils ??,,,IF transformer # 37 --my reading is 390 ohms on the 78 tube side ,,,with the tube out of the socket,,,,and 385 ohms on the 75 tube side ,,with the tube out of the socket,,,Now,,I have never went to school for any of this,,,and have learned a lot from playing with this,,,JUST a Pipefitter reading schematics,,,has that,,,,Now on the 1st Det. and IF transformer #32 ,,reads out at 11.2 ohms on the 6A7 tube side with tube out of socket ,,,and on the 78 tube side it reads out at 12.2 ohms,,with tube out of socket,,this all started with no plate voltage to the 75 tube,,I had recapped and new resister thru out,,,thank you ,,for putting up with me,,,Kenjr
Threads: 11
City: Bellmawr, NJ
Made mistake on ohms,,should read 12 ohms---on all of above,,,sorry
Ken, although your readings on ohms are high, they are not infinite (open). I wouldn't worry about those at this point. When you were referring to no voltage on the plate of the 75, were you referring to the detector plates or the triode plate? The detector plates should really show very low voltage. And no, adjusting the trimmers on the transformer will not change resistance on the coils. Don't even touch them at this time!
What is the radio doing at this time?
Best, Jerry
Threads: 18
Agree. Now and then we see an open winding on an IF coil, bkut I've never heard of or seen 3 IF coils open in one set unless it was bulldozed. Anyway, windings are typically well under 50 ohms. And also agree, do not turn tuning slugs until you have everything else fixed and are properly performing an alignment.
Threads: 573
Well, maybe it was bulldozed. Or a house pet, you know, that little grey furry really cute one, that likes cheese, had a tasting session with it.
Threads: 11
City: Bellmawr, NJ
Hear we go,,the volume is about 2 ,,on a scale 1 to 10,,,,yes ,I do have voltage ( -- .43 volts) to Number 2 pin (Pt),,,Pin #1 no voltage reading,,----pin #3 & #4 (PD 1 &2),, --5 volts,,-----pin #5 (K) no voltage reading---pin #6, ( H),, .01 volts ???? Now,,I can tell you this,, Part #55-- 70,000 ohms resister has 280 volts on it,,,then we have Part # 57 condenser .15 uf,,at that point we have a voltage of .005 volts,,next is part # 56 --99,000 ohms resister--no voltage reading,,,, So,,I though that the 110 mica (part #39A) was open because I couldn't get a reading on it,,,even after removed,,installed a new one ,,,same volume,,,I tried changing out #57 capacitor also,,,,I am lost,,,could it be that the tube could be shorted??? I didn't pull this tube while turn on with voltage,,while checking for voltage,,,,thank you for your help,,Ken
Hi Paulo,
Welcome to the Philco Phorum.
I can see why you want to find good reproduction parts. That is a bea...MrFixr55 — 11:10 PM |
Tim,
I have some bakelite sockets in my work shop that I can dig up. I believe quite a few are NOS. I will take photo...RodB — 10:03 PM |
> The cathode as noted is wired directly to the ground side of the heater filament for that tube, not to the #17 and ...Radioroslyn — 08:12 PM |
Tim;
I noticed your post a little late, but I would take one of the junk sockets and try to break a chunk out of it wi...Arran — 08:07 PM |
Here is a list of resources found in our online library that you might find useful. Mike's Gobs of Knobs email addres...klondike98 — 01:46 PM |
First Radio restoration
Hi Tubeman,
Welcome to the Philco Phorum. Phamily Phriendly Pfun with Phine Pholks Phull of Philco Phacts. (See a p...MrFixr55 — 12:33 PM |
You could post in the WANTED ADs section here on the Phorum and see if anyone has an RF generator that they want to sell...klondike98 — 11:55 AM |
Good ideas, thank you Arrange and Rich. I have the adhesive aluminum foil already and can try that immediately.
More ...EdHolland — 10:18 AM |
Murf;
I found this thread on the ARF, the first photo has a pretty good view of the dial glass.
ArranArran — 01:12 AM |
hello Ed,
how about that speacial tape used for ducting it's like foil or how about thin piece of
aluminum roof flash...radiorich — 12:19 AM |
There are currently 1398 online users. [Complete List] » 1 Member(s) | 1397 Guest(s)
