Philco 38-116 Audio Input?
Threads: 5
City: Phoenix AZ
Just wondering if this is an Audio Input for my Philco 38-116 code 125... haven't seen it on other pictures of this model, surely it didn't come with the original radio did it. I'm guessing it was an audio input added sometime later???? I tried to plug a standard RCA audio plug to see if it it fit but it was a bit snug.... any idea what it is?
https://www.flickr.com/photos/58236519@N00/16309912127/
Threads: 573
Yes, looks like audio added by someone, but the surest way to find out is to trace it.
However the most practical way is, when the radio is wirking, touch the central contact with a metal pin held by hand, if it hums, it is then the audio input.
Threads: 5
City: Phoenix AZ
Yeah haven't got to the point of plugging her in yet, seems like there are some obvious broken wires to look after first, just was curious since I couldn't get a standard plug to fit in very well. I am just getting started and have heard that if it is plugged in wrong the chassis could be dangerous to touch and the audio in plug seems a bit loose so I was worried that it might be a problem if it touches the chassis. Is the 38-116 one of the types that the chassis could be hot? I was also looking at the power plug and it seems pretty old and flimsy ( the prongs wiggle back and forth quite a bit), just curious if I should also replace that and if so do most replace with a modern three prong and if so what do you do with the extra wire, just leave it?
Threads: 337
City: lawrenceville nj
lou
1 recap
2 check resisters and replace
3 change cord 2 prong is fine
not a hot chassis I move mine while out of cabinet and playing
plug looks to be a old phono rca plug
I would check wires if ok and works leave it in
sam
Threads: 573
One thing I always do before starting on a radio with a power transformer is checking the power tansformer. If it is shot, depending on the radio you might reconsider the whole resto effort.
City: Sedona, AZ/Placentia/CA
Morzh (see I spelled it right) is correct as is Sam. Always check the "iron" first so you know what your getting into on expense. Those are great radios but nice to know if you have some major expenses to look at. Power transformer, output transformer and field coil. All good then on to caps and resistors which are cheap.
Best, Jerry
Threads: 573
Power transformer, though, is more of a discouragement if it is shot. Go try to find that one.
Threads: 5
City: Phoenix AZ
So how would one go about testing the power transformer?
Threads: 337
First thing i look for is burnt wire and bubble stuff coming out of wire coating or black wax coming from trans
Louxwe, you pull the rectifier tube and turn the radio on. Measure one plate to ground and then the other with your meter set to some high voltage A/C. You can also measure the filament voltage on that tube base to make sure it is in speck on a low voltage A/c. Be careful, there are some really high voltages off the plates to chassis. You can also do just a resistance measurements with the radio unplugged. Report back.
Jerry
Threads: 5
City: Holiday TN
Smell and asphalt dripping are indications of transformer trouble.
Looked at a lot of your pictures & didn't see anything like asphalt dripping out of Xformer. BTW nice pictures. Lucky you don't have the rubber insulation on the hook up wire that has fallen apart.
Do the light bulb / dim bulb in series with the AC power and pull all the tubes before trying power on the Xformer - you gotta pull em sometime anyway. A 25W bulb should be plenty big. With no tubes should be almost no current, only thing I see are a couple of pilot lights.
Anyone know what went on the back of the 3 small speaker frames. Clean so looks like something has been removed. Were they speakers? The mechanical behind the cone looks like passive radiators which seems weird in an open case.. The only diagram I have is Beitman 38-116 and it is a code 121. Audiophool has a 39-116 also a code 121 and a quick glance shows the 39 uses a 80 rectifier. Both of those only show 1 speaker.
Cut speaker cone leads sounds like a speaker had a problem. Someone left the plate lead / choke coil. My guess the RCA jack was for an external PM speaker.
As Jerry says watch the AC on the plate supply winding. The 39 uses different outputs but schematic has voltages and gives the PS high voltage as 370 VDC. As a full wave that would be around 270-0-270 VAC plate winding. If it is the same as the 39, transformer leads would be yellow - yellow green - yellow. about 540 VAC yellow - yellow. Considering: - rectifier loss + rectifier filament would not be surprised to see 600 VAC yellow - yellow
(This post was last modified: 02-25-2015, 07:54 PM by K7Sparky.
Edit Reason: clarification & spelling
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM |
Hello Ed,
yes, I like letting projects run for few days to make sure they don't start acting up .
Sincerely Richardradiorich — 01:03 PM |
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM |
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM |
Refinishing Ideas
Hi Doppelganger,
After rereading your thread, did you mount the Zenith speakers in the two bottom left and right pos...MrFixr55 — 09:39 AM |
Philco model #20
Hi Rick,
One other thing regarding volume on this set. Make sure that the tube shield is in place. this is that la...MrFixr55 — 08:22 AM |
Philco model #20
Hi Rick,
The volume control on the Model 20 has 2 sections and does 2 seperate things:
One part of the control, ...MrFixr55 — 10:30 PM |
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM |
Yes - better it happened on the repair bench than returning to the owner.
The other question is - do I also dissect a...EdHolland — 09:08 PM |
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM |
There are currently 1340 online users. [Complete List] » 3 Member(s) | 1337 Guest(s)
