Metal oxide varistor
What is the opinion of the multitudes about adding a mov on the line side of the radio. Given the modern power grids and there inherent power problems in the rural setting. Just a thought. Icon_mrgreen
Just my opinion.
Tube electronics are not terribly vulnerable to the type of surges that an MOV is designed to squelch. Rarely could they get beyond a transformer and in the case of a transformerless set (domestic radio) there's not much to damage.
Hey Robert
I too would tend to agree with that. On the other hand, I live in Florida and we have a lot of lightning and switching transients on the line. Now a lightning strike in the right situation will damage/burn up/ hurt the feelings of your power tramsformer and take the MOV any way. I put one in mine anyway as a "hopeful help" in case of a surge event. I also put a thermistor in series with its AC mains. It provides a softer start at power on and also lowers the primary volts by 5-6 volts while operating and hasn't affected the performance.
By the way, MOV devices have a finite life span dependant on their exposure to surges. A 500 JJoule device will take, 1- 500 joule hit; 2- 250 joule hits; 100- 5 joule hits; (you get the idea)in its lifetime. There is not a practical way for the average person to test them and a bad one looks as good as a new one. Yup, all those power strips youve had all these years are likely in need of replacing too!
Dave Casazza
Keep em glowin and goin...
DCASAZZA, hi. Could you expand a little on that thermistor. Size ( Ohms, Watts etc.). I have 120VAC as most people do nowadays and was looking for a way, simpler the better, to knock it down a few volts to get closer to the 110 ACV the sets were designed for. PL
Many folks are using the CL-90 Surge limiter/"thermistor". Its specs are about right for normal radios like we usually work on. You can get a spec sheet at Mouser. They will knock you down a few volts in normal operation but they also add heat in doing so. They get quite hot. Slows down warm up time but not terribly.
I'm fond of the Dale/Xicon chassis mount resistors, mainly because I inherited a good stock of 18/22 ohm ones at a good price Icon_smile Other guys cob in a bucking filament transformer which is a no-heat solution and also works well but presents physical limitations.
Need Help to ID this radio 11 tube Philco
Philco 16 is not intimidating at all. Despite being an 11-tuber. 37-116 is indeed intimidating. 16 has good space unde...morzh — 04:11 PM
48-482 rear panel help
Thanks for the responses Gary and Bob. I'm a little surprised that there's no back panel - although I know older Philco'...keithchip — 04:09 PM
Gary is correct, there was not a rear panel on the 48-482. I restored one of those and its a great sounding radio that ...klondike98 — 03:24 PM
A little light positivity in our feed... To nostalgic retro music... With English subtitles My new video on the contin...RadioSvit — 02:14 PM
My Philco 37-116 Restore
Ron and Mike I mentioned a 2 meg resistor not on the schematic. I stumbled on a changes note in Riders that mentioned th...dconant — 12:02 PM
Here you go: Your the code 125Radioroslyn — 11:12 AM
Hi Ron, Thanks for the input. I think I'm going to call it good enough. It does seem weird I can usually dial in othe...dconant — 08:01 AM
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
There are currently 2127 online users. [Complete List]
» 2 Member(s) | 2125 Guest(s)
