Wire wound resistor value
Quote:I have this broken resistor and need a value, it won't test but the body is brown, red paint on one end and a green dot in the middle.
http://www.nostalgiaair.org/PagesByModel...005364.pdf
Hi Kirk
What tube and pin is it connect to?? Looks like it's pin5 of the 43 tube.
ps Do you have a solder sucker???
Did a little research and it's 512 ohms. A carbon replacement is fine. 500 ohms @ 1/2-1watt is the ticket.
GL OM
Thanks Terry,
Someone said it was 625 ohms see below:
The resistor is 625 ohms 1/2 watt, item 19 on the schematic.
It doesn't use the same color code as dogbones.
It uses:
??? = blue = 6. This may be missing due to disintegration of the part.
end = red = 2.
dot = green = 5.
Was he wrong? I put in a 680 ohm resistor before I saw your post. ugh!
Kirk
No worries you can leave the 625 in there. The value isn't terribly critical, it set the bias for the output stage. Also better to be a little high than low in value. I saw a 625 ohm resistor in an other Fada schematic with a 43 in the audio output. But thought I would go with color code.
I want it to be correct, If you say it is not important here that's fine but where is the chart for these resistors for the future?
Is it still body end dot?
Thanks
Kirk
Here's one for you.
http://www.philcoradio.com/tech/resistor.htm
Thank you Ronnie old buddy old pal!
Kirk
Philco model 40-100
Arran, I restored 2 Canadian battery-crank telephones for a friend a while ago, a Northern Electric (Canadian version of...MrFixr55 — 08:04 AM
Road Trip for a Philco 46-480
Beautiful work, a 79 year old radio brought back to life. The first FM radios for me, a little iffy, had some I just cou...Jimradio — 08:01 AM
I was a field engineer for a biomedical company for many years. Many was the time that I was driving home from NYC in t...MrFixr55 — 06:40 AM
Don't laugh folks, I have not been above taking a chassis into the bathtub (when Ms. Fixr was out of the house), taping ...MrFixr55 — 06:02 AM
Philco model 40-100
Marion; By "newer style" carbon resistors do you mean the molded type with coloured bands rather then the BE...Arran — 01:00 AM
hello jrblasde , your radio sounds great well done !! I bought like 20 years ago a Philco 610b that someone had painte...radiorich — 11:50 PM
Philco model 40-100
Arran, I just can't tell if the volume control has been replaced. The control has a brass shaft with one half flat for ...mhamby — 11:08 PM
Philco model 40-100
You may be able to make the part out of wood. The particular vendor has a habit of disassembling radios and selling the...MrFixr55 — 10:09 PM
Used to get to Bentonville when I worked for a Walmart vendor....nice and sleepy back then. PaulPaul Philco322 — 09:49 PM
Philco Model 249 made in England
Did Garrard produce stand-alone turntables? The reason I ask is, when I was a kid my grandfather gave me a KLH Model 20 ...jrblasde — 09:37 PM
There are currently 553 online users. [Complete List]
» 3 Member(s) | 550 Guest(s)
